Results 1 to 20 of 24
Thread: Lifter or bearing?
11-22-2014, 11:19 AM #1Junior Member
- Mar 2006
- Florida
Black- 98 trans am
Lifter or bearing?
Motor has been doing this for some time know. Lost my oil pump. What does this sound like lifter or bearing? Valve springs and prods look good.
11-22-2014, 11:25 AM #2Senior Member
- Apr 2010
- Alabama
Moved to the internal section. I can't listen to the video right now but I'll listen tonight and post my thoughts.
1998 Trans Am WS6 - Phantom
421 LQ9 14.8:1 on E85 Build/
11-22-2014, 12:05 PM #3Junior Member
- Mar 2006
- Florida
Black- 98 trans am
11-22-2014, 08:40 PM #4Spaz is My Mentor
Starting to sound like when my rod bearings spun.
With it being a 98 and you said you lost the oil pump I'm fairly certain the best case is to pull the motor and check out the rod bearings. If you run it much more you WILL HAVE a much more expensive fix.
Mine started out like that and quickly deteriorated to the point it grenade internally. I spun 3,4,5 main bearings (and yes it's possible), rods 3,5,6,7,8 spun with 7 & 8 cork screwing the rod crank journals. The piston skirt on 7 & 8 were cracked and blew a hole in the block. Had a quarter size aluminum piece playing pinball internally.
All of this because I bounced off the rev limiter twice while doing a burn out because I missed the release on the line lock.
11-23-2014, 04:10 AM #5Junior Member
- Mar 2006
- Florida
Black- 98 trans am
Wow. Yeah it dont sound good. Im going to pull the head and take a peak before i pull the motor.i will push on a couple pistons and see if i got some play.
11-23-2014, 04:19 AM #6Senior Member
- Apr 2010
- Alabama
Okay I listened to it now. It could be a rod bearing like Scott said. I would check the lifters first though. I missed that your oil pump had went out, in that case I would bet heavily on it being a rod bearing.
11-23-2014, 04:28 AM #7Junior Member
- Mar 2006
- Florida
Black- 98 trans am
Yeah i put a new oil pump in just to see if the top end was not getting any oil and the same sound is still there. So it might be a rod bearing. Got plenty of oil pressure know though.
11-23-2014, 05:42 AM #8Spaz is My Mentor
Lifter or bearing?
quickest way would be to lift it up and use a probe on the oil pan and lower block while it's running. If you hear noise on those there's no longer any doubt.
6.0L Block - Forged 403ci
, Polluter Stg3 Cam, FAST 102mm Intake, NW102 TB, MSD wires, NGK TR6 plugs, Truck Coil Packs, LS3 Fuel Injectors, CC Pacesetter LT Headers, TS&P ORY, QTP e-Cutout, Magnaflow Muffler, 104mm Air Lid & Line Lock, Catch Can, Stage 2 T56 w/Viper shaft, PRO 5.0 Shifter, Tick MC, SPEC Stg3+ Clutch, QT SFI BH, MWC DSL, Full UMI Performance Suspension, Viking Coilovers, YR1 Snowflake Wheels wrapped in NT555 tires & Custom Fab Ford 8.8 rear w/Wavetrac Diff 3.93 Yukon Gears, WSQ Hood, 3"CM Strange Eng Drive Shaft.
11-23-2014, 10:40 AM #9Junior Member
- Mar 2006
- Florida
Black- 98 trans am
Done started taking apart waiting on rain to get out of here.
11-30-2014, 09:13 AM #10Junior Member
- Mar 2006
- Florida
Black- 98 trans am
Lifter scarred up pretty good looks like it got ahold of the cam lobe.
11-30-2014, 09:14 AM #11Junior Member
- Mar 2006
- Florida
Black- 98 trans am
So i guess i need to pull motor and flush it real good. Try to get all the metal out.
11-30-2014, 11:42 AM #12
Absolutely. That or short block it.
12-01-2014, 03:50 AM #13
Eeeuuwww!!! That's ugly. Looks like a roller that was hanging up. I've had roller needles bite the dust before and do exactly that. Camshaft is done. Trash throughout the engine. At a minimum you are looking at a complete tear down to a bare block to have it hot tanked. That crap gets packed in the damndest places that you'll never get out otherwise.
With any luck you won't have scarred up bearings and crank, but if it was run for any length of time I see a rebuild in your future, otherwise that engine won't be long for this world.
12-01-2014, 07:36 AM #14Spaz is My Mentor
I see you have listed a 98'. Original LS1 and oil pump? How many miles?
I ask because as great as the 98's are their major weakness is the oil pump.
12-01-2014, 03:18 PM #15Junior Member
- Mar 2006
- Florida
Black- 98 trans am
It has 180k on it. Yeah im going to pull the rod and main bearings and see how they look. Prob disassemble and get cleaned even if bearings look good.
12-01-2014, 07:55 PM #16Spaz is My Mentor
Lifter or bearing?
Do it right.....new bearings after a shop checks the rods & crank for wear/damage. Do not reuse bearings eith 180k miles on them. You'll kick yourself later if you do.
A MUST - Replace the oil pump w/ Melling 10295 or LS6 oil pump. I'm willing to bet the oil pump fail or got weak over time and contributed to the other failure. Know 97- 99' LS1 problem.
12-02-2014, 05:08 PM #17Junior Member
- Mar 2006
- Florida
Black- 98 trans am
I got a brand new mellings 10296 setting in garage. Yeah im going to pull it apart and go thru it with new bearings and all. Just lazyness oil pump has been going bad for sometime should of replaced it along time ago and would of been good to go.
12-02-2014, 06:23 PM #18Spaz is My Mentor
Lifter or bearing?
I have it in my block. Talk about an upgrade. @ idle op was @ 60psi.
You need to consider adding a full 6 qrts of oil and maybe a taller oil filter. At high rpms if you have just 5 to 5.5 qrts you can suck the pan dry.
12-15-2014, 03:16 PM #19Junior Member
- Mar 2006
- Florida
Black- 98 trans am
12-15-2014, 03:18 PM #20Junior Member
- Mar 2006
- Florida
Black- 98 trans am
All my bearings look good. My cam bearings is showing some copper.
Throw-out bearing or Pilot Bearing going out? Need help.
By werewolf in forum Manual TransmissionReplies: 3Last Post: 04-11-2013, 05:19 PM -
Question: Photo of rocker bearing next to lifter bearing?
By thomasterrible in forum Internal EngineReplies: 4Last Post: 06-22-2012, 12:02 PM -
Bad lifter
By bigrondownhiller in forum Internal EngineReplies: 7Last Post: 07-26-2009, 04:14 PM -
Pontiac Lifter Guide - Lifter Lowdown
By Ed Blown Vert in forum Firebird / WS6Replies: 0Last Post: 10-09-2008, 06:10 AM -
Help: Lifter??? Bearing ??WTF?(video)
By JoshieDoom in forum Internal EngineReplies: 13Last Post: 08-12-2008, 05:32 PM
