Results 1 to 20 of 45
11-07-2014, 06:32 AM #1Member
- Sep 2008
- Atlanta, GA,Ft.Walton Bch,FL
- Blog Entries
- 1
silver- 99 ws6
excessive rear end back lash be reduced w/ hand tools?
Can excessive rear end back lash be reduced w/ hand tools?
Vehical is a 99 Chevy Astro van w/100K miles van runs excellent except
For the clunk.
When at a stop light the rear end seams to clunk if I let off the brake
to quick, I’m thinking there could possiablley be excessive rear end
back lash, can this be reduced w/ hand tools like can I remove the cover and tighten the carriage bolts? or some other bolts?
Or is the gears just worn out?
all I have done so far is check the fuild level which is fine and the fuild is still a brownish color.
I plan to later jack the right wheel off the ground and twist it to see how much loosenes there is how much is to much?
What all Chevy vehicals have the same complete rear end that can be swapped into the Astro? the 99 has rear drum brakes.
Thanks for any helpful advice.
11-07-2014, 09:26 AM #2Spaz is My Mentor
Over tightening the bolts will result in crush bearings and excessive ware on the races.
The extra play you're needing to address will require rebuilt. The parts aren't too expensive. IIRC a total bearing kit cost me $140 for my 8.8 rear. It's the pinon setup that takes the time & tools that cost.
11-07-2014, 02:31 PM #3
You sure that isn't excessive drive-shaft play you're hearing?
11-10-2014, 05:28 AM #4Member
- Sep 2008
- Blog Entries
- 1
silver- 99 ws6
11-10-2014, 05:32 AM #5Member
- Sep 2008
- Blog Entries
- 1
silver- 99 ws6
while Van was in Park I crawled under and grabbed the driveshaft w/ my hand and tried to twist it it wouldn't move any.
was this the proper way to check a drive shaft?
OK according to this man
car should be in neutral w/ one wheel off the ground.
I'll recheck sure hope it's a worn U joint instead of a rear end.
ThanksLast edited by qwik219d9; 11-10-2014 at 05:46 AM.
11-10-2014, 06:44 AM #6Former Mopar Man
- Jun 2011
- Branchville, NJ
rebuilding a GM 10 bolt rear is not that tough but if you have never done this type of work before and this is your DD you will want a pro doing the work for you. Expect to pay about 600 to 700 including parts and labor.
11-10-2014, 12:58 PM #7
I would bet on about three other possible issues before I would suspect excessive backlash as being the source of the clunk.
11-10-2014, 06:05 PM #8
11-10-2014, 07:10 PM #9
Only other possibility is a loose caliper.
11-11-2014, 04:18 AM #10
My vote is the u-joint.
11-11-2014, 05:27 AM #11
U-joint. Any update?
11-11-2014, 06:53 AM #12
11-11-2014, 06:11 PM #13
Been a few members that have had that issue over the years. My Moser is set up loose and although it whines and carries on with the tunnel mount torque arm, it doesn't clunk or bang.
11-13-2014, 07:15 PM #14Member
- Sep 2008
- Blog Entries
- 1
silver- 99 ws6
OK Guy's remember this is a 10 bolt on the Chevy Astro van.
I have been reading a lot of stuff that will cause this clunk even on new trucks and vans, I have only visually inspectedhe U joint it appeared intack I will jack the wheel up and twist and move driveshaft for u-joint movement.
I have also read that the shocks could cause this clunk how would I inspect this?
I have also read the rear drum brakes could be hanging up how is this checked?
It seams the most common response on the net is that the front of the drive shaft the splines that attach to the trans, are dirty and need cleaning and greasing.
If the rear end infact needs to be rebuilt can I use a Posi (GM code G80) diff. from a F-body RE. in the Astros 10 bolt housing? from what I understand about the Astros housing is it is off set and each axel is a different length however some Astros did come from the factory w/ the posie RE.
This Van will eventually get a LS type motor and 4L60E so I'm planning ahead.
edit: this clunk is intermitant like today I was cruising around and it didn't clunk once.
ThanksLast edited by qwik219d9; 11-13-2014 at 07:23 PM.
11-14-2014, 02:32 PM #15
As the shock bushings wear out, they loosen up and you can have metal-to-metal contact between the shock and the mount. Drum brakes can hang up when they are wet -- my Ranger used to do it all the time. It helped to take a angle grinder with a sanding disc and bevel the ends of the pad. I can't imagine the driveshaft splines are an issue -- they are internal to the back of the transmission and are totally sealed from dirt and debris -- plus the splines are lubricated by transmission fluid.
11-15-2014, 06:01 AM #16Member
- Sep 2008
- Blog Entries
- 1
silver- 99 ws6
Jeff do the wheels have to be off the ground to test the shocks or there bushings?
the other day when I was under the Van looking for loose stuff I grabbed the shock and tried to move it it was solid probablley because of all the Vans weight was on the ground.
I didn't observe oil leaking from the shock, I also pressed down on back of Van serval times to see if it would continue to bounce (like w/ a worn shock) and it didn't.
can I replace just the shocks bushing if they are worn?
ThanksLast edited by qwik219d9; 11-15-2014 at 06:05 AM.
11-15-2014, 06:16 AM #17
On our Suburban, I was able to rattle the shock with the truck up in the air and the axle hanging. Guess it depends on where the noise is emanating from as to whether you will be able to reproduce it. I always just change out the shocks -- even good ones are not too expensive. It is the Konis and such that cost an arm and a leg.
11-16-2014, 06:42 AM #18Member
- Sep 2008
- Blog Entries
- 1
silver- 99 ws6
Concidering air shocks for rear for a few reasons
smooth air like ride will it be like riding on air for rear passengers?
can the rear stock ride height be lowered a tad for cruising around town?
Here’s what I’m concidering
http://www.ebay.com/itm/Gabriel-air-sho ... bf&vxp=mtr
I will be occasionalley towing a 2.4K LB boat w/ about 180 LB tongue weight, I also expect a nice smooth ride.
Maybe I can air up a tad when towing then air down when cruising.
How is this air adjusting done like do I mearsure the current stock ride height from the back bumper to the ground and use that as a bench mark?
Also if I get new air shocks for the back will the front require new air shock, regular shocks or can I leave the orginales on? I’ve read the fronts are a bit difficult to install.
Edit: the air hose w/ these shocks is there like a bracket that holds the air tube schader valve and is this tube like a Y-ed tube that airs/unairs both shocks? Also mounting suggestions would help.
The Van has a smaller OE spare under the back.
Thanks
11-17-2014, 03:41 PM #19Senior Member
- Feb 2006
- Orange County, NY
Air shocks act like an adjustable helper spring. You add air to level the truck out. It the same as filling a tire. You should recheck the ujoints. Park the van on level ground and block a wheel so it doesn't roll. Put it in neutral. Then try to rotate the driveshaft. If you feel play in it you can narrow it down to where it is coming from. While down there push up on the tranny tailshaft to check the tranny mount.
11-19-2014, 05:55 PM #20
I had air shocks back in the 80's -- rough ride but the rake was cool.
I Call BS! 5-min fuel pump swap with hand tools?
By Naaman in forum General HelpReplies: 11Last Post: 11-14-2016, 07:48 AM -
House Democrats in Dispair, ..Lash out at Pelosi!
By wileyCoyote in forum Political / Debate ForumReplies: 1Last Post: 11-18-2014, 10:46 AM -
Valve Lash In A Flash!
By Ed Blown Vert in forum General HelpReplies: 0Last Post: 09-23-2014, 03:10 AM -
Excessive?
By Sarge in forum Almost Anything GoesReplies: 68Last Post: 06-17-2009, 09:01 AM
