09-28-2014, 12:21 PM #1
Blown ENG SEN fuse, troubleshooting results inside....
Okay so I know what components are on this fuse. I hooked up a DMM from the fuse to ground in "beep" mode. Disconnected the 4 02 sensors and the skip shift solenoid, couldn't get the reverse lockout solenoid connector off but does not matter.
With these disconnected, no short to ground. As soon as I connect anyone of the 4 02 sensors, it's shorted to ground.
Anyone have an idea what would cause this? I can see one bad 02 causing the problem, but this is tied somehow to all four?
Thanks up front.
09-28-2014, 05:48 PM #2
I just happen to have my shop manual next to my computer with the engine schematics. The ENG SENS fuse runs to junction S104 where it splits to all four (4) of the O2 senders. If there is a short in one, there is then a short in all the way it looks. It is the pink wire that runs to each of the sensors that is on this circuit. If you need more info, post up and let me know.
09-29-2014, 04:43 PM #3
Jeff I figured that out after I posted so I have to check connect each 02 sensor one at a time and check resistance through it to ground. I suspect that I will find one that is close to a short while the other three read some finite amount, perhaps 10 ohms or greater.
The continuity test will beep even if there is some low resistance, I wasn't looking at the meter as it was on top of the car. I need another pair of eyes this time!!
Thanks for the support.35th Anniversary LE # 167 SLP # 1084
09-29-2014, 05:54 PM #4
Let me know what you find.
10-01-2014, 04:26 PM #5
Well its not the 02 sensors, one at a time plugged them in and measured 6-7 ohms on each. Disconnected the reverse solenoid and skip-shift solenoid, so all 4 02's and MAF connected. and started the car. Fuse did not blow so it is one of the two solenoids. Over the weekend I will plug in on at a time and see which one blows the fuse then order that part.
Let you know which is the culprit. Hope its the skip-shift, M U C H easier to get to.
add an auxicilary fuse box inside under the da
By qwik219d9 in forum Stereo and ElectronicsReplies: 10Last Post: 07-06-2010, 04:34 AM -
A/C fuse blown
By tapout in forum General HelpReplies: 6Last Post: 04-22-2010, 05:20 PM -
WTB Inside fuse box cover...
By Liveforfunjim in forum Parts Wanted / TradeReplies: 3Last Post: 07-26-2007, 06:49 PM -
Took the cobra to track yesterday! Results inside!
By Musclefan21 in forum Almost Anything GoesReplies: 24Last Post: 03-21-2007, 04:35 PM
