Results 1 to 19 of 19
Thread: Steering Issues
09-24-2014, 07:42 AM #1
Steering Issues
In the last couple of months my steering wheel went from feeling tight to now very loose.
My rack and pinion is fairly new. Roommate says steering knuckle. Read through all the past threads and no one replied back about if things got fixed, etc.
What could be possibly causing this?
09-24-2014, 07:53 AM #2Spaz is My Mentor
any vibrations from the steering wheel as you drive?
09-24-2014, 07:56 AM #3
Nope. None at all.
Still very responsive, just "slack" in it.
10-01-2014, 07:05 AM #4
10-01-2014, 08:30 AM #5Spaz is My Mentor
Have you checked all of the tie rods?
10-01-2014, 08:55 AM #6
10-01-2014, 09:09 AM #7Spaz is My Mentor
How old is the pump?
You'll need someone to look or turn the wheel.
With the vehicle off, try to slightly turn the wheel, but not enough to turn the wheel. Look to see how much free play you have on the steering shaft.Last edited by SMWS6TA; 10-01-2014 at 09:11 AM.
10-01-2014, 09:26 AM #8
Pump is as old as the car.
10-01-2014, 09:44 AM #9Spaz is My Mentor
It may be starting to go...
10-01-2014, 10:16 AM #10
Slack usually indicates worn parts -- it is a rack and pinion so even if the pump is whipped the steering input will result in movement of the wheels, just the effort to move it will be increased. There is a clamp bolt where the steering shaft connects to the rack -- I would check this ASAP to ensure that it has not come loose and the "D" shaft is wearing away.
10-01-2014, 11:00 AM #11
D shaft? I'll check that clamp bolt, but that other thing, no clue.
10-01-2014, 11:21 AM #12Spaz is My Mentor
Steering Issues
<wondering if they tighten that.
10-01-2014, 03:40 PM #13I like turtles
- Aug 2007
- Corn and Soybean fields
Steering effort decrease? Free play in the wheel or the wheel itself flopping around like Michael J Fox?
10-01-2014, 03:46 PM #14
10-05-2014, 07:32 AM #1511 years of bangin gears
- Jan 2009
- North Jersey
Worn rack bushings, maybe?
12-12-2014, 05:38 AM #16
UPDATE!!
I fixed it!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!
That 11mm bolt from the steering column into the rack was about to fall out. I tightened the crap out of it and my awesome steering is back. Yay!!!
12-12-2014, 06:15 AM #17Senior Member
- Apr 2010
- Alabama
Glad it was a pretty easy fix.
1998 Trans Am WS6 - Phantom
421 LQ9 14.8:1 on E85 Build/
12-13-2014, 04:17 AM #18
Holy wow Jodi. Have you been driving the car since you started this thread?
12-13-2014, 05:03 AM #1911 years of bangin gears
- Jan 2009
- North Jersey
That's a scary thought. Bolt falls out while on highway=REALLY NFG
Anyone have power steering issues?
By RedFenix_68 in forum Firebird / WS6Replies: 17Last Post: 03-29-2016, 03:46 PM -
Steering Issues
By 79Firebird_99TA in forum Suspension and HandlingReplies: 8Last Post: 07-10-2013, 05:37 PM -
Power steering issues
By 1998ss in forum General HelpReplies: 15Last Post: 02-12-2011, 09:59 PM -
Question: Steering issues
By 99TAguy75 in forum Suspension and HandlingReplies: 9Last Post: 06-01-2010, 07:49 PM -
Power Steering/cooling issues...
By RPO_WU8 in forum Camaro / SSReplies: 2Last Post: 08-18-2007, 09:03 AM
