Results 1 to 2 of 2
    Blown, Stroked, & Sprayed
    Ed Blown Vert's Avatar
    Aug 1999
    No Where
    383 Procharged & N20 Vert
    Exclamation Car and Driver uncovers trouble with Corvette Stingray's LT1
    Filed under: Coupe, Performance, Chevrolet
    There are two kinds of supercars: those made by niche manufacturers and those made by mainstream ones. The niche supercars tend to be a rarer and more exotic sight, but some buyers opt for more mainstream supercars because, for one reason at least, they'll be more reliable. Right?
    That's not always the case, as Car and Driver recently found out. The publication's Corvette Stingray long-term tester blew out its LT1 V8 engine entirely after only 6,000 miles, necessitating a complete replacement. Fortunately, it was under warranty, but it contributed to the 'Vette having to spend an inordinate amount of time in the shop - something you might expect from a small Italian manufacturer, for example, but not from one of the largest automakers in the world.
    The problem apparently boiled down to metal debris from a bad oil filter getting into the lubication system, knocking out a con-rod bearing and totaling the engine block. GM is reportedly investigating the issue, which was just one of several problems C/D encountered with the flagship Chevy, but which haven't stopped our compatriots in Ann Arbor from enjoying the time they've had so far with the all-American supercar, or from taking it on long-distance road trips to Indiana, Chicago, even Virginia and New Jersey.Car and Driver uncovers trouble with Corvette Stingray's LT1 V8 originally appeared on Autoblog on Mon, 08 Sep 2014 13:29:00 EST. Please see our terms for use of feeds.
    Permalink | Email this | Comments
    More...
    hmmmmm.....who's making ac delco filters these days?
  1. 2014 Corvette Stingray
    By SiggyZ in forum Almost Anything Goes
    Last Post: 05-04-2013, 08:16 AM
  2. Driver side header trouble
    By 98TransAmWs-6 in forum External Engine
    Last Post: 07-05-2010, 12:38 PM
  3. Corvette Stingray concept
    By trev0006 in forum Corvette
    Last Post: 02-22-2009, 07:41 PM
  4. Chevy Corvette Stingray - The Corvette Diaries
    By Ed Blown Vert in forum Corvette
    Last Post: 05-30-2008, 09:50 PM
  5. 1974 Corvette Stingray
    By Tonik in forum Member's Rides
    Last Post: 10-27-2006, 02:14 PM
