Results 1 to 10 of 10
Thread: Codes P0171 & P0174
08-29-2005, 03:46 PM #1Junior Member
- Texas
Black- 2000 WS-6
Codes P0171 & P0174
what could be causing these codes? they have been on for a bit. i can clear them and they will stay of for a while but come back on. and occasionally it will go off itself but not for long.
thanks in advance.
08-30-2005, 12:45 PM #2Spartan_AngelGuest
Just wanted to say Gig 'Em ... but I can't help you with your problem, lol
08-30-2005, 02:40 PM #3Senior Member
- Jul 2005
- Jacksonville, FL
You're running lean on both banks - sometimes people get these codes with an aftermarked MAF - assuming your stock here's a few things to check out on the diagnostic page in Helms when you throw both codes together:
exhaust leaks
precat 02 sensors secure
vacuum leak
intake air leak
I'd also make sure the MAF connection is good and the MAF itself is clean.
09-08-2005, 06:57 AM #4Senior Member
- Aug 2003
- Honolulu HI
Pewter- all bore 370 Trans Am
have you recently messed with the intake manifold? if so, then thats your problem. are you running a k&n filter? you maf elements could be covered with oil from it and be throwing it off also. If its been that way for a while, you may also want to consider new o2 sensors. What mods do you have done and whats the last thing you messed with?
09-09-2008, 01:19 PM #5Junior Member
- Nov 2005
- Orlando,fl.
Black- 2001 Camaro SS
I have the same exact thing going on with my 00 z28. Except when they come on my idle starts to drop. I was thinking it was the 02's. I did not know it could be this other stuff.
09-10-2008, 07:23 PM #6
I had same code problems, turned out to be slp maf. Installed stock one, no more codes. 200$ waste of money.
09-11-2008, 08:01 PM #7
yes, a list of mods would be helpful.
09-14-2008, 10:41 AM #8
if stock MAF, then a vauum leak is most likely. one of two spots. the most likely is the rubber line between the PCV valve and intake. it likes to rot from the underside. typical. second would be the EGR tube seal slipped out of place.
09-15-2008, 02:39 PM #9Junior Member
- Nov 2005
- Orlando,fl.
09-15-2008, 05:33 PM #10
usually it. i see you are in orlando. you coming to my birthday on the 21st?
http://www.ls1.com/forums/showthread.php?t=95956
Help: P0171 and P0174 error codes
By initechpeter in forum Firebird / WS6Replies: 18Last Post: 09-19-2013, 02:48 AM -
Codes P0171 and P0174
By 00LS12LS6Z28 in forum External EngineReplies: 13Last Post: 08-27-2011, 11:38 PM -
P0171 and P0174
By LSCyaL8R in forum General HelpReplies: 24Last Post: 11-10-2010, 05:50 AM -
p0171-p0174 and 704 codes!!! help!!
By maro1360 in forum Internal EngineReplies: 0Last Post: 04-20-2010, 05:21 AM -
p0171 p0174
By SandmanWs7 in forum General HelpReplies: 2Last Post: 10-23-2007, 10:56 AM
