Thread: Fuel Pressure Regulator Issue
08-03-2014, 11:06 AM #1Junior Member
- May 2014
- Spencerport, NY
Blue- 1985 S10 Pickup
I plan to put a Vortec 6.0L engine and trans. in my 1985 S10 pickup truck. I have a 15 gal. fuel cell in the bed and have a 58psi Corvette fuel filter/regulator mounted with a Walbro 255 external pump and will run only one fuel line to the rail. My question is what do I do with the OEM fuel pressure regulator on the rail. Of course I have to block off the end of the fuel rail, but should I just remove the vacuum line and plug it and be done or is something else I should do and will the constant 58 psi cause a over rich condition at idle due to the constant 58psi that the PCM may not be able to compensate for at idle?
08-03-2014, 02:50 PM #2
The fuel pressure regulator is contained in the stock fuel bucket, not on the rail. That may be part of the evaporative emissions system, if you are referring to the small can on the driver side above the rocker cover.
10-26-2017, 05:46 PM #3
That small can on the drivers side fuel rail is the fuel pressure dampener.
Ported/Polished throttle body, Lingenfelter launch module, SLP line lock, QTP exhaust cutout, LS7 clutch, K&N, Ceramic coated longtubes, no cats, 3" exhaust, Flowmaster "B", Eibach springs, Midwest Chassis 9" rearend w/4.10's
10-27-2017, 04:18 AM #4
^^ I stand corrected. Good catch.
Help: Fuel pressure regulator
By erick3566 in forum GTOReplies: 0Last Post: 09-05-2016, 09:01 PM -
Trans am Starting issue, Fuel Pressure Regulator?
By mrfriendly23 in forum General HelpReplies: 4Last Post: 04-13-2010, 07:26 PM -
Fuel pressure regulator q
By grandkodiak in forum LT1Replies: 2Last Post: 08-11-2009, 08:41 PM -
By Goldcuffs in forum General HelpReplies: 0Last Post: 04-28-2009, 05:36 PM -
fuel pressure regulator ?
By 5150 in forum Camaro / SSReplies: 2Last Post: 12-08-2005, 03:25 PM
