Results 1 to 17 of 17
Thread: Monsoon aux adapter?
06-23-2014, 08:15 AM #1Junior Member
- Jun 2014
- Connecticut
Black- 99 Trans Am WS6
Is there an aux adapter that I can get for the monsoon radio? If so where? I usually like going all aftermarket, but would rather keep the original radio in my t/a
06-23-2014, 08:36 AM #2Senior Member
- May 2013
- Nashville, TN
Black / White- '00 T/A M6/'19 Hemi Truck
You've only got a few options...one is the AUX mod which requires cracking the radio open and soldering some wires inline with the CD player that taps into the input. It tricks the radio into thinking your iPod is a CD. Works really well.
Second one is the inline AUX box then plugs into external CD player connection if you have an external CD player. Crutchfield carries them.
Third is an FM transmitter that plugs into your antenna connection in the back of the radio...they aren't your standard cheap ones from BestBuy. They are anywhere from $50-100 on Amazon and you have to tap into power behind the dash to power it.
Those are pretty much all of the available options for the monsoon system.2000 Black TA M6 - LT's, ORY, UMI Short Stick, TT2's, Drilled/Slotted Rotors, Braided Lines, and Tuned by Vengeance
SCCA and Car Show Approved
06 Quad Cab HHHHemi - Sold
97 Camaro - Sold
06-23-2014, 09:02 AM #3Junior Member
- Jun 2014
- Connecticut
How do I go about option one?
06-24-2014, 06:30 AM #4Senior Member
- May 2013
- Nashville, TN
this should get you pointed in the right direction...if you dont like soldering or reading wiring diagrams you probably arent going to enjoy this mod very much
How you can add an aux input/mp3 player without an adapter - LS1TECH
06-24-2014, 07:20 PM #5Junior Member
- Jun 2014
- Connecticut
Thanks. Looks pretty simple to do
06-24-2014, 08:19 PM #6
It is. I did mine in less than an hour the other night. Here is the write up I did on my blog about it.
Monsoon Aux input Mod
I used the exact thread posted above to accomplish it.
06-25-2014, 05:53 AM #7
06-25-2014, 05:58 AM #8
06-25-2014, 06:29 AM #9
06-25-2014, 09:27 AM #10
No tape player, mine was just the standard CD deck. I'm not sure if that would cause any trouble making it work or not. I would think that as long as you have the head unit set to use the CD and you're tapped into the right cables for left & right channel that it would work. I would look through that thread on LS1Tech and if they don't mentioned a tape deck ask about it. Jason Novak was pretty quick to respond when I had a question about the cables in mine.
06-25-2014, 09:53 AM #11
I have to do this. Very good pictures.
06-25-2014, 09:58 AM #12
06-25-2014, 10:38 AM #13
06-25-2014, 10:43 AM #14
Here you go. Found a post where Jason did a tape deck.
LS1TECH - View Single Post - How you can add an aux input/mp3 player without an adapter
06-26-2014, 05:43 AM #15
06-26-2014, 06:16 AM #16
06-26-2014, 06:29 AM #17
Yep, I just used an old patch cable I had laying around. The CAT5 will have 4 twisted shielded pair in it, but you only need 5 of the wires. They are twisted in colored pairs... blue/blue & white, orange/orange & white, green/green & white, brown/brown & white. I chose the blue pair for one channel, the orange for another and then green for my ground then snipped the other off to keep confusion down and have them out of the way. Another reason I liked using a CAT5 cable is that it is solid core and easier to deal with than stranded, especially when trying to thread it through the tiny holes in the aux switch you are wiring in. When wiring the ground my advice would be to leave the connector ground alone and put it on the radio chassis. If you look on at one of the sides, there is a screw that is holding another piece of metal still on the inside. I made a loop on my ground wire and used that screw to ensure a solid ground.
monsoon adapter
By txman4362 in forum Stereo and ElectronicsReplies: 0Last Post: 07-03-2008, 08:25 AM -
2 din adapter for stereo
By scotthd in forum General HelpReplies: 1Last Post: 06-08-2008, 05:52 AM -
Ipod / MP3 / RCA Aux Input Adapter GM Monsoon
By at100plus in forum Stereo and ElectronicsReplies: 12Last Post: 11-10-2007, 05:10 AM -
Coax to RCA adapter?
By grandkodiak in forum Almost Anything GoesReplies: 8Last Post: 11-28-2006, 11:09 AM -
WTB SLP Loudmouth LT1 Adapter Kit
By DMAX/Hemi in forum Parts Wanted / TradeReplies: 0Last Post: 04-08-2006, 11:19 AM
