    Minnesota
    '10 ZR1
    Question Factory GM 12 bolt posi rear end question
    So - I am completely changing the rear suspension in my '68 (Camaro). It currently has a 12 bolt posi in it.
    If you had a 12 bolt posi, and if you wanted to sell it - what price tag would you put on it? That would be including the axle shafts, drum brakes - the whole nine yards.
    Feb 2007
    San Diego, CA
    2002 Z28 A4 NBM
    Sadly now demodded :(
    Depends on condition of the axles and bearings. What gear ratio and also it's condition.
    My guess would be from $500 to $1500 for a serviceable unit to a great condition unit. Might be more if it's an original 68 rear axle assembly in ecxellent condition and you find a restorer that needs it for his car.
    I value the one in my 67 at ~$2500 but it has new(er - I had it all rebuilt many years but not so many miles ago) axles, seals and bearings along with a GM 4.10 gear set with rebuilt Eaton posi AND it's an original 67 Camaro 12 bolt (mono perch) with the factory welded on traction bar attachment.
    If you can get me some info off of the axle assembly (date code, part number and application) I can inquire over on Team Camaro
    in the "What's it worth" area for you.
    If you don't know how to find this info you can check out the CGR (Camaro Research Group) web site. They are dedicated to 1st gen info and have been for almost 20 years.
    67 Camaro: K-K + 797-z (look it up), 454/Th400/4.10 12-bolt = 6mpg, PS/PDB/PW tilt, tach, gauges...
    Carbon footprint? CLOWN SHOE!
    Minnesota
    '10 ZR1
    Thanks 67! I'll see if I can get some info for you!
  1. Question: 7.5" 10 bolt rear torsen fluid question.
    By 2002ssslp in forum Drivetrain
    Last Post: 07-29-2012, 04:07 AM
  2. 12 bolt Moser 3.42 Posi.
    By Double0me in forum Drivetrain
    Last Post: 01-03-2012, 09:22 AM
  3. 10 bolt rear end cover question?
    By 02blckws6 in forum Drivetrain
    Last Post: 07-29-2010, 02:43 PM
  4. For Sale: 10 Bolt Rear-End, Eaton HD Posi, 4:10 Gear
    By '99 SLP#24 in forum Parts For Sale / Trade
    Last Post: 05-23-2010, 06:11 PM
  5. Used Eaton posi for 10 bolt rear.
    By blackdog in forum Parts For Sale / Trade
    Last Post: 08-09-2005, 05:45 PM
