Results 1 to 14 of 14
    Member slade8200's Avatar
    NH
    02 SS #8850
    Balance weights really needed on outside of rim?
    More "expensive" cars don't have them. But they always put them on my wheels. The stick-on weights on the inside of the rim can't be that bad, can they?
    Member speedyWS6's Avatar
    Sep 2009
    U.K.
    2002 WS6 TA
    I flatly refuse to let my tire guy clip on any
    outside weights! I always go to the same guy and he "gets" my
    anal attention to detail. He once even dis-mounted
    and re-mounted a tire as the row of stick on weights could not be
    placed behind a spoke!!
    Careful balancing can always be addressed with stick on
    weights.
    Just ask and make sure you get what you want.....
    Apr 2010
    Alabama
    Black/ Silver
    98 TA WS6/ 01 C5 Corvette
    As long as the surface is clean there is nothing wrong with stick on weights. That is what I use and I have yet to have a problem.
    1998 Trans Am WS6 - Phantom
    421 LQ9 14.8:1 on E85 Build/
    Agree. I always go with stick on weights. Never had an issue.
    Indianapolis
    2000 WS6 6spd Hooker LT
    Just make sure you have a competent tech and balancer. Then you will have no problem. Our Hunter Road Force never has a customer complain about vibration, and we hide the weights behind the spokes as a courtesy.
    yep....you have to make sure you tell them you want stick on's.
    Arizona
    I have my own tire changer/balance machine and I have always static balanced everything just because I have never liked to look at the weights on the outside of the wheels.
    I've used both stick on and knock on wheel weights on the insides. 99% of the time I prefer the knock on weights, and I carry different styles to fit different wheel lips. I just find they stay on without issues and I get a better balance with the weights furthest outside. I'll use stick on occasionally on wheels that won't accept knock ons, like Ansen aluminum mags for instance, but the wheels have to be super clean or they won't stay on there for long.
    I just tell them to put them on the inside. Otherwise, they always seem to want to put them on the outside.
    Arizona
    Yep, my experience was that nearly all places will want to dynamic balance the wheels (weights on both sides) unless I specified. The explanations I used to get were because they wouldn't guarantee vibration free with just a static balance. Always used to get "the look" from the tech too, lol.
    I don't mind wheel weights on both sides when I'm running steel wheels with beauty rings because you can't see the weights anyway, but if I have to stare at the weights, then it's static balance only.
    North Jersey
    Phantom Black Metallic
    2004 GTO M6
    I spray some brakleen on a rag and wipe the inside of the wheels real good then throw on the tape weights. If the customer requests tape weights, I oblige without a second thought. No complaints from customers.
    Arizona
    One thing I notice, and this depends on the brand of wheel and the brand of tires, is that static balancing can take a little more weight to get the assembly to balance since you are relegating weights to only one side.
    With a good wheel and tire combo it's not bad at all,, but I've had some cheaper stuff in here that takes what I consider an excessive amount of weight. Sometimes in those cases it's better to dynamic balance for a better end result.
    Member sjgreen6's Avatar
    Dec 2009
    Mechanicsburg, PA
    Navy Blue
    2002 Trans Am WS6 Conv
    +1 on using the Hunter Road Force balance system. It costs more but for those of us who are extremely picky about things there is a difference.
    Indianapolis
    True, but putting the weights only on the inside does not necessarily mean it is a static balance, as the weight that would normally be on the outer flange is only an inch or so away from there. It is still dynamically balanced, but may require a *bit* more weight. Most people easily feel the static imbalance before they will feel the same amount of dynamic, hence the Hunter Smart Balancers.
    Arizona
    Yeah my electronic spin balancer has the ability to balance that way as well, with 3 options of 2 rows of weights on the inside of the wheel depending on the design of the wheel so you can program a dynamic balance all on the inside of the wheels in different configurations.
    However I don't care to do that, I prefer the static balance with a knock on weight on the inside lip only and avoid all the stick on stuff that would be needed on the second inside row with a dynamic balance. I would likely resort to that if I had a really stubborn wheel/tire combo, but I just haven't found it necessary on my stuff. As long as you have a good OEM wheel with a quality tire, they balance pretty easily this way.
  1. Wheel weights
    By 024mula in forum Wheels and Tires
    Last Post: 03-12-2013, 04:00 PM
  2. Wheel weights!!
    By blackSS01 in forum Wheels and Tires
    Last Post: 05-25-2011, 04:02 PM
  3. Hood weights?
    By MistrCreazil in forum Firebird / WS6
    Last Post: 11-14-2009, 07:38 PM
  4. Mixed oil weights.
    By seratt in forum General Help
    Last Post: 08-29-2008, 02:36 PM
  5. Question: Wheel Weights
    By Selah in forum Wheels and Tires
    Last Post: 04-13-2008, 09:38 AM
