Results 1 to 19 of 19
Thread: throttle bodies
04-28-2014, 09:49 AM #1
throttle bodies
Thinking about getting an bbk 85mm intake manifold. What is the stock size throttle body for a 98 ls1 ta ?.
04-28-2014, 11:01 AM #2
IIRC it's 78mm
04-28-2014, 06:23 PM #3
^^ Sounds right.
Personally, I would recommend a stock LS6 over a BBK intake.
04-28-2014, 07:45 PM #4
:yep: Nothing but nightmares in fitment.
04-28-2014, 09:15 PM #5
- Apr 2010
- Alabama
I had a 96mm Professional Products intake which is similar to the BBK and I sold it for a FAST 102 because the fitment was horrible on it and it required rtv just to not leak around the injector ports, runners, etc. I would highly suggest a LS6 intake if you don't want a FAST 102 over the BBK.
1998 Trans Am WS6 - Phantom
421 LQ9 14.8:1 on E85 Build/
04-29-2014, 02:12 AM #6
If I had to go aftermarket, then it would be the new FAST 92 mm that comes in black... but only if I could get myself to swallow the $900 plus price tag.
04-29-2014, 06:02 AM #7
04-30-2014, 04:11 AM #8
throttle bodies
what would be a good suggested throttle body for a stock ls6 intake ?
04-30-2014, 04:23 AM #9
throttle bodies
I wiped out a wrist pin the motor was pulled and had to do a small bore to a 353 to fix the damage. added a set of long tube headers and a 3" y pipe . if any of that helps in directing me In the right direction on the intake manifold and throttle body
04-30-2014, 04:27 AM #10
throttle bodies
also made a custom aluminum pipe to replace the accordion style plastic tube connecting the ram air box to the motor
04-30-2014, 07:44 AM #11
04-30-2014, 10:36 AM #12
Still running the stock TB on ours. I see a lot of guys running Nick Williams without any complaints or issues.
04-30-2014, 12:49 PM #13
throttle bodies
also will I need to replace the mas for a larger TB
04-30-2014, 04:41 PM #14
You can pick up good ported TB's on Ebay cheap.
Look for the place that has a chick with a big rack holding the TB or PM me for the name.
04-30-2014, 06:02 PM #15
Stock MAF will support up to around the 500 hp level. Most people use a Fernco adapter to mate the MAF to the larger throttle body while others delete the MAF completely and run a speed density tune.
05-08-2014, 01:03 PM #16
throttle bodies
Ok so I ran across a great deal and snagged a bbk ssi 85mm intake with a matching 85mm bbk throttle body and a jet 85mm maf with new intake gaskets still sealed in box that was bought for a build till they had money problems got it all for $600
05-12-2014, 02:14 AM #17
^^ Pics of the install, please, when it happens.
05-14-2014, 07:21 AM #18
- Nov 2012
- Roanoke, VA
Sebring Silver- 2000 Trans Am
I've got the BBK intake, installed it about a year ago. No leaks but I did run into issues with the coolant lines under the intake. Since it was a Saturday night and I had no time to get the LS6 conversion parts I made my own. Basically had to eliminate the pipes that go under the intake. I tried to smash them down flatter, still would not clear. I think they also shorted me some fasteners. Don't forget to loctite the fasteners on the bottom of the intake, I hear they can come loose.
05-14-2014, 07:23 AM #19
- Nov 2012
- Roanoke, VA
BTW I called BBK and complained, figured their engineers might want to know. They offered me some lame discount on my next part.
Question: throttle bodies
By 383ls6 in forum External EngineReplies: 0Last Post: 02-18-2011, 02:32 PM -
c5 throttle bodies
By c5lover in forum CorvetteReplies: 1Last Post: 05-10-2008, 02:02 AM -
Throttle Bodies
By kevan in forum GTOReplies: 2Last Post: 01-30-2008, 09:21 AM -
Throttle bodies
By smokeum99ta in forum External EngineReplies: 2Last Post: 01-02-2008, 06:20 PM -
throttle bodies
By crazyhorse in forum Eastern MembersReplies: 4Last Post: 12-12-2007, 03:44 PM
