Results 1 to 11 of 11
Thread: LQ4 Partout
04-26-2014, 02:10 AM #1
LQ4 Partout
I am parting out an LQ4 that I picked up for a 408 build. Pretty much everything is up for grabs except for the block and a few items I am keeping for the build. Some of these would go well with an LS transplant into older muscle or if you just need some items for your truck. Most of these prices are just me pulling some numbers out of the air since they are required for the listing. If you are serious about wanting a part, make me a fair offer and I will consider them all. All prices are without shipping. I was told this motor came from a 2005 Silverado 2500 with around 150K miles that was t-boned in an accident. Thanks for checking out the listing!
Well, apparently there is a small limit on the amount of pictures that can be included in a posting so I had to cut out over half of them. If you see something listed that you want a pic of that isn't shown below let me know and I will post it up in the comments.
Wiring harness with fuse block - SOLD
Coil packs with brackets - SOLD
Alternator - SOLD
MAF - SOLD
DBW Throttle Body - SOLD
Starter - SOLD
Coolant temp sensor - SOLD
LQ4 crank pulley - $30
Crank position sensor - SOLD
Camshaft position sensor - SOLD
Vortec intake cover - $10
LQ4 intake tract hose - $15
Knock sensor - $15
Lifter trays - $15
Oil pressure sending unit - SOLD
Plug wires - $10
LQ4 power steering pulley - SOLD
LQ4 pushrods - $15
LQ4 steam vent and plugs - SOLD
Valley cover - $20
Napa upper radiator hose for truck - $15
LQ4 dipstick and tube - SOLD
LQ4 motor mounts - SOLD
LQ4 power steering pump - SOLD
Timing sprocket with chain - $10
Stock LQ4 Camshaft - SOLD
Stock LQ4 24x crankshaft - SOLD
LQ4 driver exhaust manifold - $30
LQ4 flexplate - SOLD
317 heads - SOLD
LQ4 intake with fuel rails and injectors - $200
Lifters - $40
Truck oil pan with windage tray and pickup tube - $100
Oil pump - $30
Truck Blue/Green PCM - $100
LQ4 pistons with connecting rods - $100 Will separate rods and pistons if needed
LQ4 power steering and alternator bracket - SOLD
Truck water pump - SOLD
Truck A/C compressor bracket - $50
A/C compressor - SOLD
Lifters - $40
Oil pump - $30
LQ4 pistons with connecting rods - $100 - Will separate if needed
04-26-2014, 05:19 AM #2
Dipstick and tube sold
04-27-2014, 04:18 PM #3
04-30-2014, 09:07 AM #4
Crank and Cam sensors - SOLD
04-30-2014, 02:12 PM #5
PS pump and Pulley - SOLD
05-04-2014, 02:36 PM #6
05-05-2014, 05:18 PM #7
05-08-2014, 02:44 PM #8
LQ4 camshaft - SOLD
05-13-2014, 05:59 PM #9
Q4 flexplate - SOLD
06-02-2014, 05:29 PM #10
317 Heads and A/C Compressor are SOLD
06-20-2014, 11:29 PM #11
Coolant Temp and OPSU are SOLD
1998Procharged CAMARO PARTOUT/12BOLT/BUILT T56/P1SC/interior
By 9t8z28 in forum Parts For Sale / TradeReplies: 51Last Post: 08-29-2011, 05:07 PM -
99 Trans Am partout, LS1
By NorthwoodDavid in forum Parts For Sale / TradeReplies: 22Last Post: 12-21-2008, 09:22 PM
