Results 1 to 3 of 3
    T56 Front Plate Question
    Transmission has been tore down and is getting rebuilt.
    Found something of interest....Sorry for the crappy pic I was focus on the number. On the front plate on the inside side. The races that go into these 2 spots for the output shaft and the other gear shaft are "loose" when compared to the other bearing races. Those had to be pressed in while these could be pushed in by hand. At first I thought it was a bad race, bad front plate (had to get a new one) or incorrect size...etc. It took several calls to ppl and all told me that the races and the plate are correct. If you can explain why I'd feel better about this.
    Also I took this quick pic to show the difference between the old syncros vs the old. The one is the back is the new one from the stage 2 kit. You can see the old one's are shot, nothing there.
    The name says it all !!!FAST!!!'s Avatar
    Manlius, Il.
    2000 WS6, 2006 G35
    The shims go under the races. The races will clamp onto the case once the input and counter shaft races are correctly shimmed and then the case is tightened.
    Go it thx's...
  1. Need front plate holder
    By doberman 152 in forum General Help
    Last Post: 05-07-2010, 04:24 PM
  2. Question: Front license plate
    By Tmont in forum Mid-West Members
    Last Post: 02-10-2010, 07:08 AM
  3. Trans Am front plate question
    By RJS1 in forum Appearance Section
    Last Post: 12-27-2007, 01:35 PM
  4. Front lisence Plate
    By Brownboy2020 in forum Firebird / WS6
    Last Post: 06-23-2006, 06:11 PM
  5. Front Plate
    By kronik in forum Firebird / WS6
    Last Post: 10-12-2005, 08:18 PM
