04-21-2014, 05:16 PM #1Junior Member
- Nov 2011
- St. Louis, MO
White- 2000 Trans am conv ws6
lock the door and the headlights pop up then down?
I just took my car from storage, 2000 TA, and the battery was dead. After I got it started I drove it a bit to charge the battery up. Now when I use the key fob to lock the car the head lights go up and then down real fast, as if it is flashing the lights to alert that the alarm is set. I don't want it to do this. It never did in the past. is there a way to turn this off??
04-21-2014, 07:23 PM #2
most likely the headlight gear is messed up.....pretty common and a pretty cheap and easy fix. I used bfranker's brass gears. Only takes a few minutes to swap them out.
gear is here
4th Generation Headlight Fix
youtube how to
04-22-2014, 03:58 AM #3Junior Member
- Nov 2011
- St. Louis, MO
I thought it may be some sort of an alert that the alarm wsa being set.
04-22-2014, 04:12 AM #4
yep....me too. That's pretty much exactly how it acts but in reality it's that headlight gear. Sometimes you can just flip your stock gear 180 degrees and fix it but in my case that didn't work.
04-22-2014, 07:05 AM #5Junior Member
- Nov 2011
- St. Louis, MO
Sounds good. I'll just replace the gears. I'm sure the brass will be better than the plastic
Power door lock doesn't work on drivers door..
By 99RedTa6spd in forum Firebird / WS6Replies: 3Last Post: 09-03-2014, 08:20 AM -
JHP Door Lock Kit 04-06 GTO
By CamaroFan71 in forum Parts For Sale / TradeReplies: 0Last Post: 08-06-2012, 01:32 PM -
Help: pass door lock
By gagoat in forum GTOReplies: 28Last Post: 02-13-2009, 05:30 PM -
door lock problem
By ZForce1 in forum Camaro / SSReplies: 1Last Post: 02-08-2009, 09:01 AM -
Door Lock mehcanism
By shlby123 in forum General HelpReplies: 2Last Post: 03-06-2007, 02:29 PM
