Thread: Monsoon Removal
    Apr 2014
    Alberta, Canada
    2000 ws6 Trans am
    Monsoon Removal
    Hello everyone. I am trying to remove my factory HU in order to install an inline ipod module. The problem is, the HU will only come out about two thirds and then stops. Got my hand up behind and the main wiring harness is not long enough to allow the HU to be pulled out and disconnected. I tugged on the harness a bit and it wont move. Has anyone had this problem? And if so, what was the remedy. Any advice would be appreciated. Thanks
    phoenix
    04 2500 4x4 crew cab
    That would most likely be your antenna coaxial line. It is very short. You will need to reach up and behind it from under the passenger foot well to disconnect it. This is all if I remember correctly. I tore the whole factory stereo out a number of years back. There is an alingment pin, but it isn't fastened to anything, it just slides into a hole.
    Apr 2014
    Alberta, Canada
    2000 ws6 Trans am
    ok guys, got it. The two harnesses coming from the back of the HU are taped together about 6 inches behind the HU. Where that Y in the cable meets, it was stuck on the middle back of the plastic box that the HU sits into. Squeezed my hand up there and moved both harnesses to the same side, then it came out. There is enough wire to easily disconnect the HU. The Ipod thing works good, even though I use a Blackberry Thanks az gt eater
    Member RONS98TA's Avatar
    MARYLAND
    BLACK
    1998 PONTIAC TA
    Yep, what az gt eater said. The antenna wire is stupid short. Gotta get on you back and scratch up your hand a lil to get to it from the passenger side floor.
    May 2013
    Nashville, TN
    Black / White
    '00 T/A M6/'19 Hemi Truck
    I guess im just lucky...mine comes right out if you can, shine a flash in behind the headunit and make sure no wires are wrapped around anything in the dash as well.
    Apr 2014
    Alberta, Canada
    2000 ws6 Trans am
    OK guys, got her out. The two wiring harnesses coming out of the back of the HU are taped together, and that was hooked on the back of the plastic box that the HU sits in. Squeezed my hand up there and moved the wires over and the HU popped out. Installed the IPOD thing and all is well. Thanks for the replies. Parry
    MARYLAND
    BLACK
    1998 PONTIAC TA
    Mine came out wo issue's, but on several other installs I have had the wires or antenna cable get in the way. Some cars are just dicks. LOL
    Jun 2011
    Branchville, NJ
    Silver & Blue
    02 Camaro SS, 04 GTO
    I used a pair of long nose pliers to get mine out. Worked great.
  1. Monsoon faceplate removal
    By MasonWS6 in forum Stereo and Electronics
    Last Post: 07-10-2014, 06:53 AM
  2. Complete Monsoon Removal
    By Tobynine9 in forum Stereo and Electronics
    Last Post: 01-13-2008, 07:01 AM
  3. Monsoon Atena Wire Removal?
    By kool-aide in forum Stereo and Electronics
    Last Post: 12-25-2007, 09:03 AM
  4. non monsoon headunit in monsoon system....
    By ivan1 in forum Stereo and Electronics
    Last Post: 05-04-2007, 06:34 AM
