Results 1 to 19 of 19
Thread: WS6 Headers/intake
04-04-2014, 10:07 AM #1Junior Member
- Nov 2012
- CALIFORNIA
red- 2000 WS6 MANUAL
WS6 Headers/intake
So i have a 2000 WS6 I'm looking to get some headers either Kooks or American racing haven't decided which just yet. Im wondering whether it would be best to get the 1 3/4 or 1 7/8 headers also whether the ORY would be a smart choice over the catted Y. Im looking to put on my ls6 intake and was wondering is it a direct fitment or would have to do some modifications? Also is it better to purchase the off road headers or the ones that have the egr and air fittings (not really sure what they are or mean). Thanks
04-04-2014, 10:40 AM #2Spaz is My Mentor
WS6 Headers/intake
bigger is better. Regarding the cat y that depends on your states emmissions. I've deleted my cats because no inspection here
6.0L Block - Forged 403ci
, Polluter Stg3 Cam, FAST 102mm Intake, NW102 TB, MSD wires, NGK TR6 plugs, Truck Coil Packs, LS3 Fuel Injectors, CC Pacesetter LT Headers, TS&P ORY, QTP e-Cutout, Magnaflow Muffler, 104mm Air Lid & Line Lock, Catch Can, Stage 2 T56 w/Viper shaft, PRO 5.0 Shifter, Tick MC, SPEC Stg3+ Clutch, QT SFI BH, MWC DSL, Full UMI Performance Suspension, Viking Coilovers, YR1 Snowflake Wheels wrapped in NT555 tires & Custom Fab Ford 8.8 rear w/Wavetrac Diff 3.93 Yukon Gears, WSQ Hood, 3"CM Strange Eng Drive Shaft.
04-04-2014, 10:48 AM #3Spaz is My Mentor
WS6 Headers/intake
off road headers just mean the egr tubes are left off. you don't need them and you don't have it if IIRC. If you still have the egr delete it.
The LS6 Intake will fit but some slight mod. The intake is deeper then the LS1, the issue is the coolant crossover tubes under the intake. You have 2 options in dealing with them.
Opt 1 - get a LS6 (or 3 now) coolant crossover kit. It plugs the back inlets on the heads and changes the front tube. Goes for $60.
Opt 2 - You can keep the LS1 crossover tubes but you'll need to CAREFULLY knock off the plastic fins on the bottom of the intake with a dremil.
04-05-2014, 06:22 PM #4Senior Member
- Apr 2011
- Johnstown,PA
Silver- 1999 Trans-Am, 2012 Sonic
If you have a true LS6 intake there should be NO EGR so the headers without the EGR set up is what you need
99 Trans Am, SLP Lid, Blackwing filter, smooth bellow, Ported TB, LS6 intake, Ws6 lower ram air box, OBX LT's, Magna Flow cat back, LS7 clutch, Tick MC, Hurst Shifter, Frost Tune, UMI SFC,LAC, STB, PB, Torq Arm, Super Hawk hood, Torq Thrust II, Kee Audio.
Strange S60 4:10's, D&S Rotors, S/S Brake Lines.
Nitto NT05R Track Tire's, 12.7 @ 108 / 1.82 60'
Wish list.
Coil overs, Heads & Cam
04-09-2014, 03:52 PM #5Junior Member
- Nov 2012
- CALIFORNIA
04-09-2014, 05:23 PM #6
I run the Kooks 1-7/8" headers and catted Y on our car. You'll be very happy with the look and fitment. The whole job can be completed in just a couple of hours with basic hand tools - so that price seems a bit steep to me.
04-10-2014, 06:59 PM #7
You won't even pass the visual inspection. You can't do freaky sH!t to your emissions in Cali. ORY's illegal in Cali. It has to be catted and have EGR and AIR. I believe the only thing you can get in Cali are the "shorties". There's a reason you see 49 state legal on some of the parts you buy...it's because the 50th state (Cali) doesn't allow them.
04-11-2014, 01:39 PM #8
04-16-2014, 10:34 AM #9Junior Member
- Nov 2012
- CALIFORNIA
04-16-2014, 10:52 AM #10
Without a tune the engine will be running rich and things will not be optimal. There is really no interrelationship between the intake and exhaust from an installation standpoint so it does not matter which one you tackle first. Just be sure to pop up the plastic pins that attach the rubber seal to the cowl when you start as they will shred your hands.
04-16-2014, 11:15 AM #11Senior Member
- Apr 2011
- Johnstown,PA
So that what was shredding my forearms when I did my Headers!!!!
04-16-2014, 03:34 PM #12Junior Member
- Nov 2012
- CALIFORNIA
Alright sounds good! I plan on installing the headers and y pipe and seeing how it sounds with my flow master exhaust, If i don't like the sound I will change to borla or magna flow. Would you say It would be wise to decide that first then tune it or is the catback change not relevant to the tune.
04-16-2014, 05:22 PM #13
Just a catback isn't really a worry. Add the LT's and then you'll want a tune.
04-16-2014, 06:02 PM #14
Agree with Jeff and as he mentioned earlier, a tune will net you the most power increase after the header install. It isn't an absolute necessity to get a tune, but it is highly recommended to get the most out of the setup. Several have went w/o and the car will run fine, just a little rich. I think most who opted not to get a tune were probably tight on cash as a tune isn't exactly cheap...unless you are able to go the Frost online route.
05-05-2014, 12:09 PM #15Junior Member
- Nov 2012
- CALIFORNIA
05-05-2014, 12:28 PM #16Spaz is My Mentor
4.10's in a 10 bolt is asking for it to blow up. Unless I miss you have a 12bolt or 9".
05-05-2014, 06:26 PM #17
05-07-2014, 10:38 PM #18Junior Member
- Nov 2012
- CALIFORNIA
Alright guys looks like I'm going to go with the Kooks 1 7/8 headers (non stepped don't really see the reason to go with stepped) and a catted y. I think I'm going to do it right and get rid of the flowmaster catback (even though it sounds good people say it's very restrictive). I have narrowed down to either the GMMG catback or the Kooks True Duals. What would you guys say since the cost differnce between the two is about $500. I've watched countless sound videos and am stuck between these two. All the help is much appreciated thanks again!
05-08-2014, 02:41 AM #19Senior Member
- Nov 2006
- Indianapolis
I agree a tune is always necessary to get the most out of any vehicle setup, whether stock, or with any type of mods. I must have a freak car, since everyone seems to think a tune is really helpful for headers. I ran my car for years without a tune after my LT/ORY, and I got 1.5 MPG better highway (this means I wasn't running very rich), and I was trapping 2-3 MPH faster. I had Frost do a mail order tune for me probably 4 years after my LT/ORY. I did have to see the SES light for all that time, so maybe that's why people say you must have a tune. MAF equipped cars are somewhat self-tuning, since the MAF will report the higher airflow that a good intake/exhaust set-up enables and the PCM adusts accordingly. I do get maybe .5 MPG better on the highway now since the Frost tune.
OP, how are you getting around Cali's visual emissions inspection? Some people there change their stuff out to stock for the emission inspection, then the put the headers etc. back on the next weekend.
ls6 intake or LT headers?
By nathanWS6 in forum External EngineReplies: 2Last Post: 05-13-2012, 06:14 AM -
Intake or headers
By Firebirdformula99 in forum General HelpReplies: 16Last Post: 09-10-2011, 09:12 AM -
Intake/headers
By Al Hazz in forum External EngineReplies: 2Last Post: 04-24-2010, 08:26 PM -
Intake or Headers?
By DeadLifter in forum Camaro / SSReplies: 17Last Post: 04-05-2007, 02:46 PM -
WTB LS6 intake Headers and more..........
By keno2095 in forum Parts Wanted / TradeReplies: 0Last Post: 02-10-2006, 03:18 PM
