Results 1 to 19 of 19
Thread: Brake Calipers paint or get new?
03-18-2014, 12:04 PM #1Junior Member
- Mar 2014
- Roy Utah
Metallic Blue- 2002 Trans Am WS6
So as of now I dont have the huge itch to dump tons of money into my car yet. However I do want to spend a little money on the small things that can really make a car stand out. I have drilled and slotted rotors ( look great) but just stock calipers ( looks not great) im debating whether i should just give them some TLC and paint and refurbish them or maybe spend a couple bucks on some newer ones.
So heres my question for all you, what calipers would you prefer that dont cost 700+ dollars and have a million pistons ( i dont drive that hard). would you choose for your car if your just in it for looks at this moment. ( maybe later on when im in it for speed ill no question spring for the million piston brakes
03-18-2014, 12:36 PM #2Senior Member
- May 2013
- Nashville, TN
Black / White- '00 T/A M6/'19 Hemi Truck
if you are just in it for looks and dont need any performance out of it, I would just paint them...if you want to do something really cool I would do the CTSV brake conversion. Its only for the front 2 wheels but its worth every penny.
03-18-2014, 12:53 PM #3Junior Member
- Mar 2014
- Roy Utah
I'll look into that thank you
03-18-2014, 03:11 PM #4
I kept the stock calipers on our car, but painted them. Swapping for some R1 Concepts rotors, Hawk pads and installing stainless braided hoses fixed our braking woes.
03-18-2014, 07:32 PM #5Senior Member
- Apr 2010
- Alabama
If you want to know about the CTS-V brake swap I have done it so feel free to ask questions. I personally would do the CTS-V brake swap but I am biased.
Here's some eye candy:
1998 Trans Am WS6 - Phantom
421 LQ9 14.8:1 on E85 Build/
03-19-2014, 02:14 AM #6
That looks nice, but no way they would clear my track wheels. I take it the spacer on the hub is required with the shallower rotor hat? Or is that simply to adjust the bolt pattern?
03-19-2014, 08:26 AM #7Senior Member
- Apr 2010
- Alabama
The spacer was because the wheel spokes came in too far and rubbed against the caliper but I have a smaller one I am going to try with my 17s since I discovered that they fit with pretty much no modification. I know Weld 17" RTS wheels fit with no modification if you get the right offset and pad height but those are pricey. I have R1concepts stuff to put on with it as well once I get the 17s fitted to it.
03-19-2014, 10:52 AM #8Junior Member
- Mar 2014
- Roy Utah
will this clear the stock alloy wheels? idk what it is about those stock wheels but i love the way it looks and wanna keep them on
03-19-2014, 01:59 PM #9
03-19-2014, 04:18 PM #10
if you wanted something in between you could always have the calipers powder coated. That will last much longer than paint although I did brush on paint last time and it's held up awesome compared to the first time I did them with hi temp rattle can paint. I painted them in 06 and they still look like new.
03-19-2014, 07:03 PM #1111 years of bangin gears
- Jan 2009
- North Jersey
I agree on painting the calipers. Might be doing that this spring.
03-20-2014, 02:58 PM #12
Just a question for some of you - are the calipers on a regular Camaro/TransAm/Firebird bare metal? The calipers on my 35th LE came powder-coated from the factory. They are gray.
03-20-2014, 03:15 PM #13Junior Member
- Mar 2014
- Roy Utah
Trans am ws6 and they are bare metal
03-20-2014, 03:56 PM #14
Mine were bare aluminum.
03-20-2014, 04:11 PM #15
yep...bare. I actually polished mine before I painted them the first time. There was just some areas like the back of them that would've been a shit ton of work to get to a mirror finish so I just went ahead and painted them.
03-25-2014, 03:49 PM #16
I got the nuts sucked right off of me on TECH with these.....hhttp://www.calipercovers.com/_e/1998_2002_Chevrolet_Camaro/product/14027-S-CUS/1998_2002_Chevrolet_Camaro_Firebird_Pontiac_Trans_ am_Custom_Caliper_Covers I have them .......
Last edited by 4get gto; 03-25-2014 at 03:53 PM. Reason: You cant edit your post.........................................
03-25-2014, 03:55 PM #17
Either way........go to calipercoverscom
03-25-2014, 04:29 PM #18Senior Member
- May 2013
- Nashville, TN
2000 Black TA M6 - LT's, ORY, UMI Short Stick, TT2's, Drilled/Slotted Rotors, Braided Lines, and Tuned by Vengeance
SCCA and Car Show Approved
06 Quad Cab HHHHemi - Sold
97 Camaro - Sold
03-26-2014, 03:10 PM #19
pictures ?
I did at one time.........Alot of money........maybe.......Do I have to repaint ? NOPE2000 NBM WS6
/oo_________oo\
|==_/_ws6_\_==|
><(((º>´¯`·.¸¸.·´¯`·.¸¸><((((º>
SOM T/A, Paint Color for Calipers?
By Sunset T/A in forum Appearance SectionReplies: 17Last Post: 09-08-2008, 08:34 AM -
Question: Anybody ever try Rustoleum to paint calipers ?
By Speedy_Gonzales in forum Showcar and DetailingReplies: 20Last Post: 07-26-2008, 03:19 PM -
What color to paint my calipers?
By joliver2 in forum Appearance SectionReplies: 20Last Post: 04-16-2007, 06:18 PM -
where can I get SOM paint for my calipers?
By 01SOMSS! in forum Appearance SectionReplies: 13Last Post: 01-03-2007, 06:56 PM -
which color should i paint my calipers???
By 02T/AWS6 in forum Appearance SectionReplies: 20Last Post: 10-03-2006, 09:32 PM
