Results 1 to 2 of 2
02-28-2014, 07:45 PM #1
2000 WS-6 rear hatch leaking at spoiler?
My car was always garaged and has only 32K on it (24k less than 6 months ago) and was never driven in the rain. I now, against my will, have to use it as a daily driver for a little while. I've noticed that when it rains which it does in Seattle on occasion, that when I open the hatch, water comes leaking out of the plastic on the under side of the hatch on the right side, from a small hole, by the hatch shock mount IIRC. The real bitch of it is that it leaks directly into the speaker mounted below this area.
I know some have stated the glass is leaking or the weatherstripping, but my ride is still very low miles and has not been exposed to weather or sun for a long time (in about 10 years, I only put 5k on it), so I doubt wx stripping or glass seal is an issue. I'm thinking there may be a leak where the spoiler mounts to the lid.
Ideas, suggestions, experience with this issue? Thanks
03-01-2014, 04:37 AM #2
Take the plastic off so you can see better. Crawl inside the car and have someone spray the area with a hose. You should be able to see where the water is leaking in through.
Help- unusual leaking problem - hatch area
By NastySS in forum General HelpReplies: 11Last Post: 11-30-2012, 05:13 PM -
Help: '01 Ram Air TA Rear Hatch Lift Strut Mount loose in Hatch
By NAVYGSE1 in forum General HelpReplies: 3Last Post: 12-20-2011, 01:07 PM -
2000 camaro Z28 rear spoiler
By camaross1 in forum Parts For Sale / TradeReplies: 1Last Post: 08-07-2010, 06:37 PM -
Help: water leaking from hatch
By sd1971 in forum General HelpReplies: 3Last Post: 02-09-2009, 06:19 PM -
2000 Camaro Ss Factory Rear Hatch / Spoiler - Complete In Black
By LS1W in forum Parts For Sale / TradeReplies: 7Last Post: 10-31-2007, 07:25 PM
