Results 1 to 3 of 3
    michigan
    1998 trans am
    Cleaning cylinder head bolt holes
    Cleaning out our cylinder head bolt holes is almost worst than cleaning of the graphite gasket. But this job a used a small bucket mounted shop vac I bought at home depot for $22.00 and an accessory kit made by Dewalt. The accessory kit had a small tube attachment that fit right down into the 11mm holes. Still follow up with a paper towel but this is a lot faster.
    You still need to run thread chasers down the holes. You may have gotten a lot of the debris but I can almost guarantee there is still trash in the threads. Also long q tips and many of theme. So you can get all liquids out of the holes. Otherwise you'll have the block crack.
    michigan
    1998 trans am
    yeah, agree I was just bringing up the vacuum. I vac before and after thread chaser, I use the ARP 11mm thread chaser for LS's..
  1. intake mounting holes in cylinder head
    By yellow73 in forum Internal Engine
    Last Post: 08-19-2010, 06:14 PM
  2. Replies: 0
    Last Post: 01-16-2008, 04:40 PM
  3. Pontiac Cylinder Head Packages - Cylinder Head Symphony
    Last Post: 12-11-2007, 08:20 AM
  4. LS2 Cylinder Head Bolt Torque?
    By brundag5 in forum General Help
    Last Post: 01-04-2007, 05:56 AM
