    Member RONS98TA's Avatar
    MARYLAND
    BLACK
    1998 PONTIAC TA
    Stock fuel rails
    At what H/P numbers is the stock fuel rails and fuel lines from the tank to the manifold maxed out? I have a 98 TA LS1 running stock bottom end, fast 90/90 intake & tb, L/T's, ory, stock heads,(comp cam 54-457-11) 223/231 @.050 112 lsa cam, D1Sc procharger @8-10 lbs, 60lb injectors, 255lph racetronix fp. I also have a snow meth kit running a 50/50 mix at 6 psi for extra insurance. I'm guessing i'm around 500 rwhp until I get a chance to get to the dyno to find out what rwhp i actually have. Any thoughts?
    Veteran 35th-ANV-SS's Avatar
    Wherever life takes me
    02 35th LE Camaro SS
    I have a similar set-up. I'm running the Alky kit though and have a stock motor aside from hardened push rods and new valve springs. I put down 500rwhp at around 8-9psi on a Mustang DYNO with a relatively conservative tune and through a Moser 9".
    I have the same fuel pump, but 62lb/hr Siemen injectors. I'm still running stock fuel lines and fuel rail. No issues. Not sure what the max is though. It was never brought up in conversation with anyone I spoke to.
    MARYLAND
    BLACK
    1998 PONTIAC TA
    I knew you had a very similar setup to me aside from the cam and intake. I guess by what some others have made H/P wise that I should okay, but I guess I really wont find out until I cruise it down to frost to spin the dyno. Thanks for the input.
    I think that pump will max out first. It's only good for about 600 or so HP if I recall correctly.
    MARYLAND
    BLACK
    1998 PONTIAC TA
    You are correct from what I remember reading before I purchased the pump. I guess if needed, I will install a second inline pump after the original. Id rather just install the intank twins which wouldn't be hard to do, cause I installed an access panel in the hatch when I replaced the orig.
  1. wtb need quick 97-98 corvette stock fuel rails
    By 00camaro16 in forum Parts Wanted / Trade
    Last Post: 03-29-2009, 09:20 AM
  2. Stock Fuel rails & Injectors
    By Ringmaster4x4 in forum Parts Wanted / Trade
    Last Post: 05-15-2008, 12:40 PM
  3. FS : polished LS1 fuel rails, stock injectors
    By Bad30th in forum Western Members
    Last Post: 03-10-2007, 05:29 PM
  4. Stock LS1 Fuel Rails needed ASAP
    By Linear Velocity in forum Western Members
    Last Post: 01-12-2007, 10:11 AM
  5. Stock vs aftermarket fuel rails
    By GatorSS in forum General Help
    Last Post: 01-05-2007, 08:53 PM
