Thread: Headers and fuel
01-04-2014, 07:39 PM #1Junior Member
- Oct 2013
- Brooksville Ky
Gold- 72 chevelle
Headers and fuel
6.0 swap, need to know what is the best fuel regulator to use? I'll be running a in tank Walbro 255 pump and I figure the stock reg will be a restriction, right? I was going to use 3/8's on the fuel line and return. Also, does anyone make a header kit? I am going to have to build headers for this project and I can't seem to locate a kit for the LS. Any other suggestions will be appreciated.
01-05-2014, 09:37 PM #2Spaz is My Mentor
you should be ok with the stock regulator and that pump. Only reason I foresee an upgrade would be because you went with force induction (turbo/Supercharger).
01-06-2014, 03:22 AM #3
Agree. I have not heard of any members swapping out regulators during a pump upgrade.
01-06-2014, 04:41 AM #4
I'am also curious about where does the stock fuel rails, lines and regulators max out? I upgraded to the racetronix 255 lph pump, 60lb injectors, but I still have stock lines, rails and regulator. I have a stock 98 LS1 block, crank and heads with aftermarket cam. I just installed a procharger D1SC and pushing roughly 8 psi.
01-06-2014, 02:55 PM #5Junior Member
- Oct 2013
- Brooksville Ky
Gold- 72 chevelle
I'm going to upgrade injectors, planning on 3/8S feed and return. I have a 2000 Camaro tank that looks like it's going to fit. I'll install the Walbro pump in it. Now I need to make my truck harness a stand alone and get the pcm reprogramed. Plus the rest of the truck built. Also the truck pan needs 2 inchs sawed off it. Looking for a pan is in the future.
Help: 98 TA fuel smell coming out of the fuel tank neck/cap
By JayTA98 in forum General HelpReplies: 23Last Post: 04-09-2014, 10:35 AM -
For Sale: LS1 Fuel Rail Covers with 2 Fuel Line Cutouts - Cut for F-Bo
By '99 SLP#24 in forum Parts For Sale / TradeReplies: 2Last Post: 01-11-2011, 07:24 PM -
kinked fuel line while changing fuel filter
By krese in forum Firebird / WS6Replies: 4Last Post: 10-04-2010, 04:02 PM -
LS1 all yr fuel injectors, oe fuel rail, pump,more
By Frost in forum Parts For Sale / TradeReplies: 7Last Post: 04-27-2009, 03:26 PM -
Removing fuel supply line from fuel rail
By GatorSS in forum General HelpReplies: 8Last Post: 01-02-2007, 06:10 PM
