Results 1 to 3 of 3
    Jun 2012
    florida
    E33 Disc changer
    Having a problem with E33 on a monsoon, did the typical fix, disconnect the battery and checked the connector. Any other ideas or tricks?
    Member sjgreen6's Avatar
    Dec 2009
    Mechanicsburg, PA
    Navy Blue
    2002 Trans Am WS6 Conv
    Reposted from the stereo forum
    E30 - Focus Error Cause(s): The CD player cannot focus on the disc or there is an internal focus problem. Correction(s): Try cleaning the disc or using a new disc. Make sure the disc is loaded correctly. The road could be too rough or there is too much humidity. If there is still an error, service the unit at an ACDelcoR Service Center.
    E31 - Tracking Error Cause(s): There is a problem with reading the disc. Correction(s): Try cleaning the disc or try using a new disc. Make sure the disc is loaded correctly. The road could be too rough or there is too much humidity. If there is still an error, service the unit at an ACDelcoR Service Center.
    E32 - Motor Error Cause(s): The CD motor is not handling the compact disc properly or defective magazine mounting screws are interfering with the mechanism. Correction(s): Reload the magazine. If there is still a problem, replace the magazine. If the problem continues, back out the mounting screws. If the condition is corrected, replace the screws with shorter screws or add washers to the existing screws. If this condition still exists, service the unit at an ACDelcoR Service Center.
    E33 - CD Changer Communication Error Cause(s): There is a vehicle/radio communication problem or internal radio communication problem. Correction(s): Disconnect battery voltage to the radio and then reconnect after a few minutes. If there is still an error, determine if the problem is with the radio, the harness or the changer. Inspect for correct voltage at all connectors. If there is still an error, service the unit at an ACDelcoR Service Center.
    E34 - Changer Door Open
    E35 - Changer Magazine Empty
    Try purchasing a CD Lense Cleaning Disk like this http://www.bestbuy.com/site/Dynex%26...=9302097&st=cd cleaner&contract_desc=null
    and/or cleaning , restoring the disc themselves like this How BugSpit works
    Jun 2012
    florida
    Well I found the problem and E33 does not necessarily mean communication error. There was a cd stuck up in the machine. Works now.
  1. For Sale: FS: 12 disc CD changer
    By Never-Enough in forum Parts For Sale / Trade
    Last Post: 05-26-2016, 02:04 PM
  2. For Sale: 12 disc cd changer.......
    By clg82 in forum Parts For Sale / Trade
    Last Post: 05-01-2009, 03:12 PM
  3. FS - GM 12 disc changer (New in Box)
    By aslowgxp in forum Parts For Sale / Trade
    Last Post: 06-20-2007, 06:59 PM
  4. 12 disc changer help
    By Eagle in forum Stereo and Electronics
    Last Post: 03-22-2007, 09:17 AM
  5. 12 disc changer
    By redrumta in forum Stereo and Electronics
    Last Post: 12-13-2006, 05:11 PM
