Results 1 to 10 of 10
Thread: Hatch Lift Support Strength
12-12-2013, 07:30 PM #1Junior Member
- Nov 2013
- Cincinnati OH
- 2001 Trans Am
When new, are these strong enough to lift the TA hatch automatically when release button is pushed?
12-13-2013, 02:49 AM #2Senior Member
- Nov 2006
- Indianapolis
No.
Probably so that you are the one who opens the hatch and hits something above, and now you can't sue GM about it.
12-13-2013, 05:06 AM #3Senior Member
- May 2013
- Nashville, TN
Black / White- '00 T/A M6/'19 Hemi Truck
are you talking about it opening on its own when the button is pushed or are you referring to it opening enough so that that latch actually releases...? Most people's complaint is that the spring is not physically strong enough to lift the hatch enough so that the latch releases...most people have to press the hatch release button or the remote a couple of times to get the hatch open.
if you want it to pop up quick when the button is pressed, do this mod...its quick and easy and works pretty well.
Rear Hatch Release Fix
12-13-2013, 07:15 AM #4Member
- Michigan
SOM- 2002 FireHawk
Thanks theorangeguy, I will be doing this mod come spring.
12-13-2013, 07:28 AM #5
Saw this sitting in the parking lot home depot. They sell a four pack for five dollars. 5/8 by 2 and a half inches. There are two longer ones I am sure I won't use.
12-13-2013, 09:37 AM #6Junior Member
- Nov 2013
- Cincinnati OH
- 2001 Trans Am
My question arose because I read in that install university link, the comment at the end says
"Does your hatch want to fly up to outer space when commanded to open? Great!!".
Also on my 3rd gen GTA - after switching from urethane to lighter fiberglass spoiler, half the time when I push the release button the hatch opens all the way on its own (kind of slow like power-operated liftgate on new SUVs).
On my 01 TA, the lift supports are somewhat weak but still functional.
If new ones will make it open on its own or with just a little finger boost I will change them now.
12-13-2013, 09:59 AM #7Senior Member
- May 2013
- Nashville, TN
2000 Black TA M6 - LT's, ORY, UMI Short Stick, TT2's, Drilled/Slotted Rotors, Braided Lines, and Tuned by Vengeance
SCCA and Car Show Approved
06 Quad Cab HHHHemi - Sold
97 Camaro - Sold
12-14-2013, 07:57 AM #8
12-14-2013, 10:05 AM #9
I won't be able to use them all anyways. Half are too long.
12-28-2013, 11:38 AM #10Senior Member
- Sep 2010
- Bel Air, Maryland
Silver- '02 Trans Am WS-6, 6M
Factory Third-Gens' with power hatch releases were designed to open about 3-4 inches and after an amount of time if not pulled open my a person (in case of accidental activation) close on its own. If yours opened all the way open, odds are it had an aftermarket set of hatch shocks that were valved wrong (maybe for a rear hatch with a rear wiper).
Help: '01 Ram Air TA Rear Hatch Lift Strut Mount loose in Hatch
By NAVYGSE1 in forum General HelpReplies: 3Last Post: 12-20-2011, 01:07 PM -
Question: How to replace Hatch Lift Supports for 2001 Camaro
By Thewilldog in forum General HelpReplies: 2Last Post: 11-11-2009, 04:36 PM -
'07 Escalade 6.0 Strength
By 66MONEY-PIT in forum Internal EngineReplies: 6Last Post: 06-06-2008, 08:16 PM -
VFN strength?
By daveb91 in forum Appearance SectionReplies: 3Last Post: 07-03-2007, 10:49 AM -
T-56 Strength
By xpauliber in forum DrivetrainReplies: 18Last Post: 12-01-2005, 10:14 PM
