Thread: Choosing air/fuel setup for LS1
12-08-2013, 07:18 AM #1Junior Member
- Dec 2013
- Spain
Hi, I am going to buy a BMW 325/328i cabrio (e36) and found a kit that will be a direct bolt-on in this car.
I just want the electrical to be an easy and nice looking setup. I´ve been thinking about EZ-EFI or Fast-EFI, so I´m getting rid of the stock ECU and wirelooms.
I want the MSD 6LS ignition controller too that supports Nitrous shot.
I´m just not sure about if some of the aftermarket injection setups support Nitrous. Anyone have a solution here for what I need?
12-08-2013, 06:10 PM #2
Welcome to the site!
No matter what controller you go with, you'll still have about the same amount of wiring as the stock engine harness. The simplest nitrous setup would be the type with the plate that mounts behind the throttle body and the fuel supply tapped into the end of the driver side fuel rail. Your additional fueling is then controlled by the jet size, rather than through the injectors and PCM.
12-09-2013, 08:02 PM #3Former Mopar Man
- Jun 2011
- Branchville, NJ
Just be very careful when setting up the ignition and A/F ratio. Running nitrous can make huge HP gains but it can also burn pistons so follow the instructions and start conservative and go from there. Good luck.
12-10-2013, 02:13 AM #4
I think the general recommendation is not to go above a 125 hp shot on a stock motor.
12-10-2013, 04:01 AM #5Former Mopar Man
- Jun 2011
- Branchville, NJ
^^^^^^ What Jeff said ^^^^^^
Changing my Fuel Rail setup
By ls1camino in forum General HelpReplies: 2Last Post: 09-29-2011, 04:23 PM -
help choosing a wheel setup
By ls1kid20 in forum Wheels and TiresReplies: 2Last Post: 03-04-2010, 04:41 AM -
Which Fuel Rail Setup?
By ls1camino in forum Appearance SectionReplies: 15Last Post: 09-24-2009, 03:25 PM -
fuel setup for 900+ hp
By zero_proto in forum External EngineReplies: 8Last Post: 10-10-2008, 09:44 AM -
What fuel delivery setup do you reccomend
By OreoLt1 in forum Forced InductionReplies: 10Last Post: 11-23-2006, 01:48 PM
