Thread: cutout
04-18-2006, 07:51 PM #1
cutout
i had my cutout for a few weeks now and i decided to cap it today just for fun..and for some reason the car seems quicker with the cutout capped?y?
i have a 2001 ss basically stock
04-19-2006, 06:33 PM #2
because it has more backpressure
04-19-2006, 06:36 PM #3Junior Member
- Apr 2006
- San Bruno
Blac & silver- 2000 ss camaro
what you are feeling is more low end torque, when it is open you gain more top end. in the long run , run it open you gain more over all.
04-19-2006, 06:45 PM #4Slow'er'Ass
- Thornton, CO
Closed is better for everyday driving.
Open is best for dyno pulls and track time when you are really running the car in the upper RPM's.
04-19-2006, 07:31 PM #5
depends if you had it tuned yet, its not rare to see a loss in hp when running open headers without a proper tune.
04-21-2006, 06:11 PM #6Madeche Vision...soon
- Feb 2006
- Galveston, TX
NBM- '98 Ram Air Formula
All of the above is correct. Its that simple.
04-26-2006, 02:27 PM #7
it's not because of that mythilogical backpressure. it's due to low rpm exhaust velocity. what happened when you opened the cutout is it caused the exhaust to slow down in the lower rpms. basically idle to 3000 rpms. once above 3000 rpms, the exhaust can now better utilize the larger opening in the exhaust. i've been there and done the cutout thing.
Now here's results of my exhaust endeavors. This is with 200 n2o. the stock vs cutout was same day.
distance --- stock --- cutout --- cutout colder --- Bassani
60ft ------- 1.987 ---- 2.074 ------- 2.020 --------1.969
1/8 -------- 7.902 ---- 7.912 ------- 7.990 ------- 7.739
mph ------- 93.20 ---- 93.97 ------- 92.16 ------- 98.60
1/4 ------- 12.102 --- 12.080 ------ 12.191 ----- 11.814
mph ------ 117.12 --- 118.06 ------ 118.20 ------ 121.35
NA times
60ft ------- 2.033 ---- 2.073 ------- 2.031-------- 2.044
330ft ------ 5.788 ---- 5.822 ------- 5.759 ------- 5.723
1/8 -------- 8.808 ---- 8.833 ------- 8.729 ------- 8.656
mph ------- 82.33 ---- 82.55 ------- 83.70 -------- 84.27
1000ft ---- 11.404 ---- blank ------ 11.278 ------- 11.196
1/4 ------- 13.606 --- 13.636 ----- 13.449 ------- 13.345
mph ------ 101.66 --- 101.58 ----- 104.05 ------- 105.15
yes, i gained 11/13 over stock exhaust vs open 3" cutout. again, that was after 3000 rpms. a dyno doesn't show you what happened under 3000 rpms because you start your dyno run around 3200 rpms.
cutout closed
cutout open
Cutout
By 1998ss in forum External EngineReplies: 22Last Post: 11-19-2010, 07:25 AM -
Just got my cutout....
By Red99TA in forum Texas MembersReplies: 2Last Post: 01-29-2009, 07:04 PM -
SLP lid and NEW cutout
By oneBADDz in forum Parts For Sale / TradeReplies: 5Last Post: 11-25-2007, 03:42 PM -
cutout!
By Raoul-Duke in forum External EngineReplies: 11Last Post: 11-20-2006, 02:37 PM -
Need help with cutout
By JattGunMan in forum External EngineReplies: 2Last Post: 03-24-2006, 10:29 AM
