Thread: cheap build advice
11-30-2013, 07:58 AM #1Junior Member
- Nov 2013
- alabama
cheap build advice
I'm new here snd I need advice I jus t bought a 99 ss from my friend a nd it has dropped s valve/lifter I got about 2 grand I can put into it. I'm gonna go through with all new bearings snd rings etc any suggestions on wat cam intake etc is best or best bang for my buck
11-30-2013, 09:22 AM #2Spaz is My Mentor
where in AL are you?
What are your goals? meaning nice dd, street or heavy track use?
That answer will help in giving recommendations....
There are a few of us in the middle of engine build currently. You can see mine by clicking on the link in my signature.http://www.ls1.com/forums/f7/my-6-liter-build-174257/
6.0L Block - Forged 403ci
, Polluter Stg3 Cam, FAST 102mm Intake, NW102 TB, MSD wires, NGK TR6 plugs, Truck Coil Packs, LS3 Fuel Injectors, CC Pacesetter LT Headers, TS&P ORY, QTP e-Cutout, Magnaflow Muffler, 104mm Air Lid & Line Lock, Catch Can, Stage 2 T56 w/Viper shaft, PRO 5.0 Shifter, Tick MC, SPEC Stg3+ Clutch, QT SFI BH, MWC DSL, Full UMI Performance Suspension, Viking Coilovers, YR1 Snowflake Wheels wrapped in NT555 tires & Custom Fab Ford 8.8 rear w/Wavetrac Diff 3.93 Yukon Gears, WSQ Hood, 3"CM Strange Eng Drive Shaft.
11-30-2013, 10:06 AM #3Junior Member
- Nov 2013
- alabama
Im in athens its gonna b a daily driver mostly weekens though. But I dont want it to be jo slouch either though
11-30-2013, 10:12 AM #4
Get a medium size camshaft and an LS6 intake. Add a full exhaust and you are through your budget just about. Adds up quick. You likely won't have enough left over for aftermarket heads. Look at the Torquer V2, TSP 228, or similar. You can get a custom grind camshaft too. If you're an auto, you really should match the cam to a larger stall. Lots of weak links on these cars that should be upgraded before you touch the motor.
11-30-2013, 10:18 AM #5Junior Member
- Nov 2013
- alabama
Aleeady has full exhaust with vette tips just needs headers I mught save a few dollars more and get ls6 heads if its wirth it
- - - Updated - - -
Is the texas speed cam kit wirth it or get the comp custom grind
11-30-2013, 10:28 AM #6Spaz is My Mentor
a good cam with springs, chromoly pushrods will go for $650-700 combo
A set of used 243 heads can be picked up for $400-500
I'd also recommend upgrading the oil pump as well - Melling 10295 would be a great one.
A decent daily driver cam for LS1 would be a 228 cam
- - - Updated - - -
12-01-2013, 08:26 AM #7Junior Member
- Nov 2013
- alabama
Are the 243s worth forkin out the extra cash and getting them worked? I'm wanting to stay cheap and simple but I wanna push some decent power
12-01-2013, 08:38 AM #8
Cheap, reliable, fast. Pick two.
The 243 heads ported and polished are a nice budget head for the performance, but they are by no means cheap to get worked properly.
Build advice...
By ThunderChicken in forum General HelpReplies: 28Last Post: 12-16-2010, 04:21 PM -
Question: cheap turbo build??
By Iknowthefuture in forum Forced InductionReplies: 1Last Post: 07-05-2009, 06:27 PM -
350 build, need advice
By Poppn in forum Classic MuscleReplies: 5Last Post: 09-10-2008, 11:32 AM -
wtb cheap gm car to build
By drewhenderson13 in forum Vehicles For Sale / TradeReplies: 2Last Post: 05-04-2007, 09:19 AM -
By drewhenderson13 in forum Vehicles For Sale / TradeReplies: 0Last Post: 05-04-2007, 08:50 AM
