Thread: LS1 bucks and skips in high gear
11-24-2013, 02:16 PM #1
- Apr 2009
- New York
Silver- 2002 Camaro SS
I have an 02SS Camaro that has problem skiping and bucking when you put it in 6th gear. I know it sounds crazy but this problem just started last time out with the car with no previous warning. The odd thing is my friends 01 SS has the same problem and he has been trying to fugure it out for a couple of months. My car is ALL STOCK no tuning or any aftermarket parts and it has 25k miles. My friends car has had new plugs, wires, oxygen sensors, filters and coils. Both cars are almost undrivable in high gear BUT you can lug the motor down in a lower gear with no problem. Full throttle through the first three gears is great...never would think there was a problem. This is driving us crazy anybody have any ideas?
11-24-2013, 02:30 PM #2
I do know that the one time I had the symptoms you describe, I had recently change the tranny in my probe, and the cause was that I had not re-filled the tranny with fluid. Good place to start...
12-01-2013, 05:29 AM #3
- Jan 2009
- North Jersey
Check your plug wires and make sure they all click at the coils and plugs. Also, just for peace of mind, inspect your engine mounts. I know my car used to buck in lower gears and I found one of my plug wires dangling off the corresponding plug. Re-connected and all is peachy. I also replaced my throttle pos sensor.
12-06-2013, 02:01 PM #4
- Apr 2009
- New York
Thanks for the ideas, at this point I will try anything. We are getting snow tonight so the car is parked but I will check it out.
Engine skips at hwy. speeds
By squash in forum LT1Replies: 4Last Post: 03-06-2006, 09:00 AM -
4.10 gear install was 928 bucks!!!!!
By Roastem in forum DrivetrainReplies: 18Last Post: 02-16-2006, 12:51 PM -
Car goes wild at low speeds in high gear!!! NEED HELP!!
By NeeD4SpeeD in forum DrivetrainReplies: 15Last Post: 11-09-2005, 10:59 AM -
By NeeD4SpeeD in forum General HelpReplies: 33Last Post: 10-17-2005, 03:56 PM -
high rpms out of gear
By iwantanls1 in forum Internal EngineReplies: 2Last Post: 10-10-2005, 01:20 PM
