Thread: Tire sizes
10-31-2013, 08:18 PM #1Junior Member
- Jun 2012
- columbia station ohio
07 Chevy Corvette- 2004 Pontiac GTO
Tire sizes
My buddy has an 02 chevy camaro with vette wheels on them. What tire sizes are you guys running with 17s in the front and 18s in the rear? Would like the reat to be wider than the front just not sure what sizes people recommend. Local tire shops wand a 245 in the frt and a 265 in the rear. I was thinking 275/40/17 and 285/35/18 or 295/30/18. What do you think
2004 Pontiac GTO
2007 Chevy Corvette
11-01-2013, 05:45 AM #2Junior Member
- Oct 2013
- Baltimore, Md
Blue- 2002 camaro z28
I would go with the tire shop's suggestion. A lot of guys run 255 50 16 dot drag radials on the rear and leave the front stock. I think a 245 is as wide as you can go in the front and a 255 as wide as you can go in the rear. Not sure if the corvette wheels have more of an offset to allow a wider tire or not but I run stock size on both my 5th and 3rd gen and have no complaints about handling. The 5th gen hooks up good with the new Cooper rs3-a tires. The 3rd gen has bfg g-force tires that leave a lot to be desired in traction, but it has around 500hp. I'm looking into dot drags for it. If you are having traction problems and can fit a wider tire on the rear do it, but otherwise your just wasting money in my opinion. Hope this helps.
11-01-2013, 05:58 AM #3Junior Member
- Jun 2012
The stock 17 inch wheels were 275/40/17. He just wanted to go a little wider in the rear. People have put 315s on the back.
11-01-2013, 08:20 AM #4Junior Member
- Oct 2013
- Baltimore, Md
Ok I forgot the SS came with 17's and didn't know they were that wide.
11-01-2013, 11:43 AM #5Senior Member
- Aug 2007
- Greensboro, NC
Pewter- 2002 Trans Am WS6 M6
What is the width of his wheels? Some vette clone wheels are narrower then the stock 17" 4th gen wheels.
11-02-2013, 07:52 AM #6Junior Member
- Jun 2012
He decided to go with 275/40/17 front and 285/35/18 rear. He decided on nitto 555
11-03-2013, 11:08 AM #711 years of bangin gears
- Jan 2009
- North Jersey
I think he'll be happy with the Nittos...but I'm biased.
tire sizes
By derbs in forum GTOReplies: 17Last Post: 10-28-2009, 03:24 AM -
tire/rim sizes
By stangsr4loosers in forum Wheels and TiresReplies: 1Last Post: 10-07-2008, 08:51 AM -
Need help with tire sizes.
By JwMonE99 in forum Almost Anything GoesReplies: 27Last Post: 08-20-2008, 05:41 PM -
Need help with tire sizes!
By camarossf650 in forum Wheels and TiresReplies: 9Last Post: 11-11-2007, 04:15 PM
