Results 1 to 11 of 11
10-30-2013, 10:16 AM #1
Loud whistle inside airbox near TB
Hey guys I have a loud whistle on warmup, it goes away after a few minutes, however is there any way to fix this? Any help is greatly appreciated! Take care.
10-30-2013, 11:30 AM #2
- Apr 2010
- Alabama
Do you still have the air pump or have you deleted it? If not it is probably that. Mine made a similar noise and I got rid of it and now no noise but maybe I can't hear it over my exhaust.
1998 Trans Am WS6 - Phantom
421 LQ9 14.8:1 on E85 Build/
10-30-2013, 01:26 PM #3
Its pretty much stock..ish so I'm assuming I do habe the air pump in place, ill give it a try, Thank you!
10-30-2013, 01:48 PM #4
10-30-2013, 03:21 PM #5
Roger that. Thank you for your help!
10-30-2013, 06:09 PM #6
Here's a write up on the secondary air system: http://www.ls1.com/forums/f6/seconda...emoval-130641/ The system only runs for a short time on cold start up, so very possible that this is the cause of your noise.
10-31-2013, 07:54 AM #7
Thank you soo much very useful info!
11-01-2013, 02:46 AM #8
Glad to assist. Let us know what you find once you tear into it. Easiest check would be to pull the fuse for the secondary air and see if the noise goes away. You'll probably trip the SES in the process. The system only activates on cold startup -- once the engine is warm, I can't say for certain if it runs the pump or not.
11-01-2013, 06:06 AM #9
Pump only runs on initial start up I'm fairly certain.
11-01-2013, 03:25 PM #10
That's what I thought, but it has been awhile since I read all that stuff.
11-24-2013, 06:14 AM #11
Be aware that if your state requires a "smog certificate" to register the vehicle, removing or disconnecting the air pump (where it can not be reconnected), can cause more problems than what it is worth.
SteveC
Whats this whistle
By Spikito in forum Camaro / SSReplies: 15Last Post: 03-05-2011, 07:09 PM -
Whistle = Exhaust leak?
By Head Hunter in forum External EngineReplies: 3Last Post: 08-13-2010, 07:24 PM -
whistle from exhaust?
By ScrewieStewie02 in forum General HelpReplies: 1Last Post: 04-13-2008, 11:49 AM -
T-tops start a whistle over 50?
By bgable in forum Firebird / WS6Replies: 11Last Post: 10-15-2007, 04:42 PM -
Loud Mouth or Loud MouthII
By 94camm in forum External EngineReplies: 6Last Post: 10-14-2005, 07:10 PM
