Results 1 to 3 of 3
    Poway, Ca
    SOM
    2001 Z28 (Sara)
    Thumbs up 4 Sale - Baer Eradaspeed Rotors +(front), Hawk HPS pads
    Have a set of used rotors taken off Sara (01 Z28) and the matched pads. Rotors have a little over 50% left, pads are at 70%.
    PART#BAE2301006
    GM FRONT ROTORS
    F-Body Camaro Firebird 1998 2002 Front 2301006 12.00 diameter
    The EradiSpeed+ Features: EradiSpeed+ are stock size direct replacement rotors that are a 2 piece design
    Designed to be used with factory calipers
    EradiSpeed rotors feature premium high silicon content iron castings.
    Rotor plates or outer rotor surfaces are cast with additional mass to absorb additional heat.
    Internal curved and directional vanes maximize air flow and cooling.
    Externally slotting and drilling alleviate friction losses from pad outgassing and a zinc chromate surface finish resists rust.
    Counter rotational application of slots and holes further resists pad transfer and balance issues associated with patterns which run in the conventional direction of rotation.
    Each gas relief hole drilled in an EradiSpeed rotor is located directly behind an internal vane and chamfered appropriately.
    6061 T-6 billet aluminum hat (anodized black) and bolted to the rotor
    High grade U281 fine thread stainless hardware (with captured nuts).
    $100 firm, local pickup only, San Diego area. Will not ship.
    Interested parties e mail : [email protected]
    Poway, Ca
    SOM
    2001 Z28 (Sara)
    will ship inside contenental united states for additional charge (based on zip code).
    Poway, Ca
    SOM
    2001 Z28 (Sara)
    Items have been sold, thanks so much for all inquiries.
    SteveC
  1. 4 Sale - Baer Eradaspeed Rotors +(front), Hawk HPS pads
    By SteveC in forum Western Members
    Last Post: 11-20-2013, 05:15 AM
  2. Replies: 1
    Last Post: 07-06-2007, 06:41 AM
  3. Fs: Hawk Hps Pads - Front/back Brand New In Box
    By SpeedsterZ28 in forum Parts For Sale / Trade
    Last Post: 10-24-2006, 07:34 PM
  4. Replies: 1
    Last Post: 10-11-2006, 01:23 PM
  5. Bang for buck brake upgrade? What rotors to go with hawk pads?
    By cascade in forum Suspension and Handling
    Last Post: 06-24-2006, 08:17 AM
