10-03-2013, 12:20 PM #1Junior Member
- Apr 2012
- South East Georgia
BLACK- 1998 WS6, ASC BUILD #206
Replacing 98 t/a parking light housings
Been looking a long time. Can't find a post on this so... I'll ask.
Has anyone here changed the parking light housings in the T/A yet?
As you know, the lens crack and the bulbs get wet and blow.
l ordered new lens housings and plan to change them over the weekend.
Any step by step info available will be most helpful and appreciated.
Thanks in advance.
RoyThis T/A WS6 is Factory modified by ASC at the Lachine facility on March 13, 1998 and is identified to be
ASC build #206.
We took delivery from Pontiac dealer April 7th, 1998.
ASC Factory letter provided from them.
Love of money is the root of all evil.
Send $19.95 for more information.
10-03-2013, 01:40 PM #2Member
- Urbandale, IA
Red- 2002 Trans Am WS6 (M6)
There might be an easier way but I had to replace my sockets as one was completely messed which caused the light to not function. Since I was changing one, I did both at the same time. The problem is usually the bulb warms the plastic housing (heat goes up) and eventually causes a crack. At least on my 2002 TA the socket holding the bulb is in the bottom of the housing making it the perfect spot to collect the water running in from the cracked housing.
Here's what I did:
Remove the screws/bolts from the "secret panels" under the front of the car. You will then have access to the housings through the access panels which are now open on three sides. The housings are held in place with a couple of machine screws. Remove and replace and secure the panels back in place. As before... I replaced the sockets and used plenty of dielectric grease in the new sockets to help keep moisture out for as long as possible. Make sure you check the bulbs and sockets to make sure they are still OK.
10-03-2013, 04:15 PM #3Junior Member
- Apr 2012
Kevin,
Thanks for the reply.
My sockets are in sort of a charred state but still not bad. Guess I should change these while I'm in there.
Just cut and splice the wires? I guess they will be color coded to prevent cross wiring. Hope so. :-)
Been changing bulbs for a while. The lens are cracked all across, I'm sure this is where the water is getting in.
I'll give it a try and see how it goes.
Thanks again.
10-03-2013, 04:34 PM #4
I did this long ago but upgraded to led with HD flasher.
Remove two screws for drop down panel.
Remove sockets from housing.
Several small screws, maybe an 8'ish with 1/4drive or wrench (either all from bottom or may pop open headlights to get top)
Install is reverse.
Also I had a thread somewhere, but you can remove and replace sockets without cutting. Think they were universal 3057 sockets (don't remember if 3057 or 3157,but they had universal at my parts store.
There's two little clips inside the new sockets which hold inside to the outside. Pull that out and the wires fall out.
Do the same with the stocks, I had to just demolish mine as they were burnt up. Remember what wire goes where, slide em in and clip the inside back down to lock in new socket.
Hope that makes sense on my phone.
10-03-2013, 05:08 PM #5
10-03-2013, 06:31 PM #6
Photo bucket is pretty awesome. Found this old pic. If anyone knows how to search for an image there may or may not be a relevant thread.
DRLFix.jpg Photo by chuckie669 | Photobucket
Edit. Score... go to link to other site
http://www.ls1.com/forums/f6/turn-si...0/#post1703338Last edited by chuckie669; 10-03-2013 at 06:42 PM.
The Saga of the Trans Am Parking light
By GULLETT17 in forum Firebird / WS6Replies: 223Last Post: 12-23-2019, 07:57 AM -
Question: Do your parking light bulbs get like this ?
By Blue2KTA in forum General HelpReplies: 22Last Post: 02-22-2011, 07:56 AM -
Parking light
By Alex18 in forum Firebird / WS6Replies: 12Last Post: 01-16-2010, 08:15 PM -
Help: parking light?
By LS1_ws6 in forum Firebird / WS6Replies: 8Last Post: 07-21-2009, 11:48 AM -
Parking light housing
By Justin_98TA in forum Firebird / WS6Replies: 6Last Post: 02-15-2006, 10:27 AM
