08-20-2013, 07:33 PM #1
thinking of going turbo,need advice
i have already been building my car on a different route,it has trick flow 220 heads milled,street/strip cam,and a fast 102,question is would i be able to put a turbo to this set up or would it require different heads and cam?
08-22-2013, 12:53 PM #2Member
- Sep 2008
- indiana
pewter- 2002 ws6 trans am
Your heads would probably be ok, need more info on the cam
08-22-2013, 02:02 PM #3Former Mopar Man
- Jun 2011
- Branchville, NJ
Do you have a spec card on the cam you are going to use and what is your CR ?
08-22-2013, 03:20 PM #4
My heads are milled to 61cc, with the stock graphite gaskets my cr would be around 11.1 but I have the metal gaskets so I'm not sure how much that would change the cr, my cam specs are 228/230 .588/.592 112 lsa
08-23-2013, 04:43 AM #5Former Mopar Man
- Jun 2011
- Branchville, NJ
If you are going to run more then 6psi of boost you may want to think about O-Ringing the block. 11.1 is a little high for a turbo or supercharged vehicle on the street if you want it to be reliable. I know some people out there who love uber HP will say " I'm running my WS6 with 12.5 CR with a supercharger set at 15 psi on 87 octane Quick Check gas and it runs great " Sorry guys, not going to happen. also, Forged pistons and Moly rings are a must. Good luck.
BTY, the cam specs look fine for what you are doing. Just watch out for valve to piston clearance with that CR. What ratio rockers are you using ? I would not use anything over 1.7
08-23-2013, 10:20 AM #6
Rockers are 1.7 yella Terra's, thanks for the info that's what I was trying to figure out is if I would have to pull the motor for upgrades or just bolt the turbo on, I knew that if I could bolt one up without upgrading internals and such that I wouldn't be able to push much boost, sounds like it would be better to start fresh, get a bare block and build it just for the turbo set up, I just didn't want to get rid of my heads and have to pull the engine, guess ill just have to wait, good thing is the motor that's in my car now would be going into an s10 if I start fresh with a new one
Thinking of picking up a C4, advice?
By sworn in forum CorvetteReplies: 30Last Post: 04-23-2011, 06:55 PM -
GT oweners thinking about twin turbo's please read
By blue2050 in forum GTOReplies: 0Last Post: 08-21-2009, 06:28 AM -
Question: Thinking about turbo?...
By wikked_r1 in forum Forced InductionReplies: 14Last Post: 09-07-2008, 06:02 AM -
Thinking about getting a Kimber... any advice?
By MaxPlusTen in forum Almost Anything GoesReplies: 30Last Post: 06-10-2008, 07:34 AM -
Thinking of buying 98 z28, need advice
By CDBiker220 in forum Camaro / SSReplies: 5Last Post: 05-05-2008, 06:29 PM
