    Apr 2010
    Gilroy, CA
    2001 Trans AM WS6
    Alternator Wiring
    Hi, I need to know which prong of the four wire connector the single wire from the harness attaches to. I started having alternator issues today, so I pulled the alternator out. It turns out that there is a single wire going into a four wire plug on top of the alternator. The issue is that it is a bare wire with some electrical tape on it. It appears that there was once a four position connector that plugged into the alternator, but the wire was pulled out at some time in the past and then just pushed onto one of the four prongs and taped over. I am the original owner of this car, so it must have happened at one of the shops it's been to.
    Can someone identify which of the four prongs I should attach the wire to?
    My car is a 2001 WS6
    Thanks,
    Tom
    Orlando, FL
    Mean Black
    there you go. I have a spare harness that I never installed.
    Apr 2010
    Gilroy, CA
    2001 Trans AM WS6
    Thanks. I just found the answer elsewhere also. http://www.ls1.com/forums/f6/fix-if-...re-plu-133361/
    Now I just need to get a connector.
    Apr 2010
    Gilroy, CA
    2001 Trans AM WS6
    I found it on Amazon for $11.07 delivered in 2 days. ACDelco PT1235
    That works! I wasn't sure of the P/N, but know that Caspers is a good source for specialty electrical stuff.
  1. Help: Alternator Wiring Issue!!
    By YellowTA in forum General Help
    Last Post: 05-21-2015, 05:40 PM
  2. LS1 Alternator Wiring
    By David Ray in forum General Help
    Last Post: 05-18-2009, 05:36 PM
  3. Alternator Wiring?
    By FastAssZ in forum External Engine
    Last Post: 03-24-2009, 01:37 PM
  4. Alternator Wiring Upgrade By Caspers
    By aerojt in forum Camaro / SS
    Last Post: 08-12-2008, 06:55 PM
  5. alternator wiring?
    By FastAssZ in forum Stereo and Electronics
    Last Post: 03-14-2007, 06:54 PM
