Thread: 1993 Z28 Driveshaft
07-14-2013, 05:51 PM #1Junior Member
- Jul 2013
- Burr Ridge IL
1993 Z28 Driveshaft
So a few years back I needed new u joints for my car (1993 Z28) and I decided to upgrade to an alluminum driveshaft in the process. I was told a 3rd gen F-body driveshaft would fit, so I bought one off craigslist. Problem is its about 1.5cm too short. Did the guy lie to me about the car it came out off, or do I need to be more specific in the year? It's been awhile, but I believe it came out of an 89 bird.
07-14-2013, 09:01 PM #2
Any aluminum shaft from an LS1 car is a direct bolt-in. A shaft that is 1.5cm too short is probably still engaging a good portion of the splines, but I don't remember where the splines in the shafts themselves start inside the yolk. Is the shaft too short from u joint center to u joint center, or is the yoke shorter. Overall difference is 1.5cm though I assume
07-15-2013, 05:33 AM #3Former Mopar Man
- Jun 2011
- Branchville, NJ
What he said ^^^^^^^^
07-15-2013, 09:55 AM #4Junior Member
- Jul 2013
- Burr Ridge IL
I didn't take measurements, but it has some room to slide back and fourth when I fit it in the trans end. Could it have anything to do with the fact I have a TH350?
07-15-2013, 11:48 AM #5
Well the shaft is supposed to be able to move on the splines some. And I don't know if a TH350 varies from a 4L60 in overall length. There could be some variation depending on the tailshaft on the trans. You need to set the current driveshaft next to a LS1 or LT1 factory shaft to determine length differences.
07-15-2013, 05:23 PM #6Junior Member
- Jul 2013
- Burr Ridge IL
It's short somewhere, it shakes like bad u joints but at a wide array of speeds
Wanted: 1993-1997 L460E Tranny and Driveshaft
By Dave-TransAm in forum Parts Wanted / TradeReplies: 0Last Post: 07-31-2011, 02:52 PM -
Wanted: driveshaft
By trailblazer ssss in forum Parts Wanted / TradeReplies: 3Last Post: 01-13-2009, 08:59 AM -
will m6 driveshaft fit in a4?
By Frankthetank in forum Almost Anything GoesReplies: 21Last Post: 08-12-2008, 04:40 AM -
Driveshaft!
By RYDER661 in forum DrivetrainReplies: 1Last Post: 05-30-2006, 07:19 AM -
WTB: Driveshaft
By SpeedFreakPL in forum Parts Wanted / TradeReplies: 0Last Post: 02-04-2006, 01:18 PM
