07-14-2013, 03:11 PM #1Senior Member
- Detroit
Black/Red/Black/Red- 98WS6/06MCSS/86GN/06H3
Rebuilding rear end...is this everything i will need?
For my 94 mustang 5.0..................
Ford Racing Mustang 4.10 Gears and Install Kit (86-04 V8) M-4209-G410A||M-4210-C||M-19546-A12||1300 - Free Shipping!
A local shop said they will do the install for $250-300
is that a good deal? My rear end has started whinning and sqeaking so i've been told it's time.
Also I plan on going with the mach 1 chin spoiler and i need new head lights as well cause my old ones are fogged out.
Which of these lights do you like the best?
Raxiom Chrome Mustang Halo Projector Headlights (94-98) 42009 - Free Shipping!
Raxiom Smoked Mustang Halo Projector Headlights (94-98) 49119 - Free Shipping!
One-Piece Mustang Chrome Headlight Set (94-98 All) at AmericanMuscle.com 2LCLH-MST94-TM - Free Shipping!
One-Piece Mustang Black Headlight Set (94-98 All) at AmericanMuscle.com 2LCLH-MST94JM-TM - Free Shipping!
07-14-2013, 05:37 PM #2Former Mopar Man
- Jun 2011
- Branchville, NJ
Pay your guy 250.00 cash and be done with it.
07-14-2013, 07:26 PM #3I like turtles
- Aug 2007
- Corn and Soybean fields
Unless the limited slip is shot that kit is everything you'd need. You'll need to recalibrate tbe speedo for the gears though
07-14-2013, 08:29 PM #4Spaz is My Mentor
That kit cost less then my yukon 4.10 ring & pinon gears & master rebuilt kit from Strange....
And $250 for full install - the pinon crush sleeve will make you pay that and be grateful.
07-15-2013, 04:12 AM #5Senior Member
- Detroit
07-15-2013, 08:56 AM #6I like turtles
- Aug 2007
Get it up on stands and pull the wheels. Put a pry bar between the studs on both wheels. Put one side against the ground or chassis and then try and turn the other side. If little resistance its weak if doesn't turn or it takes a good bit of effort should be good. Its also going to.come down to if you want to worry about it as well. Being a 5.0 I'd say 50/50 shot she's weak since oh so many have been babied in life lol
07-15-2013, 11:28 AM #7Spaz is My Mentor
Carpy I'm kinda going through this right now with my rear project. I have both axles in. I turn the pass side, the pion & drivers rotate, vice versa. When the pinon turns , both go in same direction.
It takes a consider amount of effort to rotate them, meaning I need to use a large screwdriver between lug studs to move the axles. With the pinon no issues.
The spider gears do not move, at all. Is something wrong or does this mean I need significant friction (tire on ground) to see if the slip posi is working correct?
07-15-2013, 03:08 PM #8I like turtles
- Aug 2007
Its best to have one side in a manner of not moving. Ie tire on ground or lime I suggested with a 2nd pry bar
07-15-2013, 08:20 PM #9Spaz is My Mentor
ok after I get it back together after cleaning out the axle tubes I'll check it that way. Installed a vent plug on the passenger axle tonight. One more thing to check off the list.
Help: rebuilding a 3.8
By austin1999 in forum Internal EngineReplies: 2Last Post: 07-06-2016, 02:41 PM -
rebuilding
By 98transamfirebird in forum General HelpReplies: 2Last Post: 10-22-2013, 07:59 AM -
Help: rebuilding the tranny
By blk_ss02 in forum Automatic TransmissionReplies: 0Last Post: 11-24-2008, 08:34 AM -
Question: maybe rebuilding this LS1
By LS-T in forum Internal EngineReplies: 3Last Post: 06-21-2008, 01:36 PM -
Anyone Up To Rebuilding A Ls1
By jbigdawg79 in forum General HelpReplies: 0Last Post: 05-17-2006, 07:38 PM
