Results 1 to 20 of 31
Thread: Strut Brace
    Jun 2012
    florida
    Strut Brace
    Is these any effect on the alignment when installing a front strut cross brace (between towers).
    Apr 2010
    Alabama
    Black/ Silver
    98 TA WS6/ 01 C5 Corvette
    Quote Originally Posted by johnfin View Post
    No, if it does at all it is so negligible that there will be no noticeable affect on alignment. I feel like it stiffens up the front end a tad but many will say it is more of an appearance mod.
    1998 Trans Am WS6 - Phantom
    421 LQ9 14.8:1 on E85 Build/
    Jun 2012
    florida
    Strut Brace
    Do you have to take all of the upper strut mount nuts off to install a brace?
    Apr 2010
    Alabama
    Black/ Silver
    Just the two nuts on each side, slide the brace on and tighten down the nuts.
    Yep.....Will's right.
    I'll add that the brand of the TSB matters too. Fitment and clearance for the hood and intake, mostly for the intake. If you have a LS1/6 intake you'll be fine, however if you have a BBK or FAST 102 you might have fitment issues.
    For straight line racing a TSB is useless. However for daily street or auto cross driving it helps in the handling. I've noticed that I was able to handle turns at higher rate of speed and not lose traction. However I also have more suspension upgrades that were installed at the same time. (see signature)
    My recommendation is it can't hurt to have.
    Apr 2010
    Alabama
    Black/ Silver
    I have a FAST 102 and the UMI brand one fits just fine. I have heard the slp one can be close. WS6 hoods and like hoods tend to not be an issue for STBs but the non ram air hoods can be from what I have heard.
    IIRC BMR has an issue with the BBK and FAST too.
    Jul 2009
    North of the Motorcity
    Custom Swirly Black
    2001 WS6 M6
    I wouldn't install it if the right or left side of the car is raised significantly higher than the other. It may not even be possible to install it if the car is torque that much. Your driveway will more than suffice.
    If you got a good price on it (I paid less that $60 IIRC, sale with free shipping @UMI), they're worth it. But like Scott said, I installed mine with other suspension components on the same day (Subframe connectors) and definitely felt a difference in left to right handling. I did notice from launch (straight line driving), the front end pulls up more level, but the SFC help out alot on that subject.
    Member Nutball's Avatar
    Dec 2012
    Indiana
    Maple Red Metallic
    2001 T/A
    I installed a QA1 STB, it's a 3 point contact. Definitely notice a difference! A pain in the ass to install but well worth it.
    STB is one of the only mods we don't have. It would just be additional weight on our car.
    West Virginia
    Y2K WS6
    Install is easy but it makes it a bitch to get to your plugs etc ... Have to pull it for a lot of mods it seems ... Great place to lean...
    FYI our cars have shocks not struts.
    I'd do sway bars and good shocks/ springs first....
    I also wouldn't do a 3 point as I have heard of them causing windshield cracking issues.
    phoenix
    04 2500 4x4 crew cab
    Quote Originally Posted by stevenm357 View Post
    The rears are shocks, the front are struts....
    A shock absorber resists the bouncing using hydraulics. That’s all it does. Struts are more complex. They combine shock absorption with steering elements and support for the vehicle. Shocks are more common on trucks and SUVs, while you usually find struts on cars. But sometimes you find both—one in the front and the other in the back. Struts are more expensive, because they are more complex.
    Apr 2010
    Alabama
    Black/ Silver
    Stbs don't make it any harder to do anything, except maybe removing the heads and things like that. But, even if it did it isn't that hard to take off, it takes like a minute or two to take off.
    Veteran 35th-ANV-SS's Avatar
    Wherever life takes me
    02 35th LE Camaro SS
    Quote Originally Posted by az gt eater View Post
    I'll disagree. Our cars have 4 shocks like stated above.
    Dec 2012
    Indiana
    Maple Red Metallic
    2001 T/A
    Can't see a 3 point STB cracking a windshield, other then on install ( like I did). It is attached to the firewall and has nothing to do with putting any kind of stress on a windshield.
    STB's are good for engine hoists. Curtis can provide a picture. Nothing more lol. If you think yours made a drastic impact...it's the Placebo effect. This has been proven time and time again over the last 13 years. It's more for show than go. It's one of the few suspension pieces not on my car.
    West Virginia
    Y2K WS6
    Just shows how little you know about how your suspension works.
    West Virginia
    Y2K WS6
    Quote Originally Posted by 98TransAmWs-6 View Post
    Gets in my San changing that back plug.... And upgrading injectors intake manifold... Granted its not difficult to remove....
    I feel with good shocks and springs you wont see any real difference in your car.
    Dec 2012
    Indiana
    Maple Red Metallic
    2001 T/A
    As I won't argue this with you Jon. I've had a 2 point STB and now a 3 point. Maybe it's just me "wanting" to feel a difference.....but, like I said, I won't argue this point as I am not as verse on the issue as you are. I'm just going on my experience with my own rides. Thanks for that bit of info though. I truly thought I felt a difference.
    phoenix
    Now I am confused, what does STB stand for? I thought it was Strut Tower Brace. And, when I changed my front struts, why did I have to use a Mac Phereson Strut Tool? From what I understand, when the coils and shocks are seperately located, the shock component is called a shock. But, when they are a single, complete unit, that unit was called a strut.
  1. 6LE Strut Tower Brace
    By MudStainKILLA in forum Suspension and Handling
    Last Post: 06-05-2012, 06:21 AM
  2. Strut Brace
    By Alex18 in forum Suspension and Handling
    Last Post: 08-31-2010, 12:14 AM
  3. Strut Tower Brace
    By jmhvenom in forum Suspension and Handling
    Last Post: 08-14-2008, 01:30 PM
  4. bmr double strut tower brace or single brace?
    By greatwhiteZ28 in forum Suspension and Handling
    Last Post: 03-30-2007, 12:42 PM
  5. Strut Tower Brace
    By skar in forum Suspension and Handling
    Last Post: 08-06-2006, 02:08 PM
