Results 1 to 16 of 16
    Member 1998 T/A's Avatar
    Aug 2008
    Huron Ohio
    2000 WS6 Trans AM
    Building a motor
    I picked up this book How to Build and Modify GM LS-Series Engines (Motorbooks Workshop): Joseph Potak: 9780760335437: Amazon.com: Books will this help me in building up an lq4/9 from scratch?
    North Jersey
    Phantom Black Metallic
    2004 GTO M6
    It should work as the LS motors are aluminum blocks and the LQs are iron. I could be wrong. Others will chime in on this topic.
    Apr 2010
    Alabama
    Black/ Silver
    98 TA WS6/ 01 C5 Corvette
    I have that book and it goes over the pros and cons of both iron and aluminum blocks. LQ4/9 is an iron block fyi. The book goes into great detail on how to tear down and build an engine. I would definitely use it, I have found it pretty helpful.
    1998 Trans Am WS6 - Phantom
    421 LQ9 14.8:1 on E85 Build/
    Yep, it's one of a few that I have that I'm using for my LQ4 build.
    Jul 2009
    North of the Motorcity
    Custom Swirly Black
    2001 WS6 M6
    Always good to have a friend that's been there before too.
    Laurel, Maryland
    2000 Grand Prix GTP
    2000 Trans Am WS6 M6
    I wouldn't trust myself to build a motor and have it last. I've always taken mine to a professional.
    Jeremy same here, it's just nice having the knowledge to make sure the shop you go to knows what the hell they claim they are doing. Shopping around for mine I've had 3 shops tell me they know about LS motors but when it came down to asking questions about honing con rods for arp bolts, aliment tools for front & rear seals I get the Monkey playing with a tambourine look.
    Apr 2010
    Alabama
    Black/ Silver
    At least you have shops to choose from there is only one shop I have been able to find around here. I'll have to ask them that same question to see if I get the same look, hopefully they actually know what they are doing when it comes to LS motors.
    Jun 2011
    Branchville, NJ
    Silver & Blue
    02 Camaro SS, 04 GTO
    Once you build your first engine you feel like a pro. I started off with a 289 ford 35 years ago and I have about a dozen under my belt now. With a good guide and some common sense anyone can build an engine. Now building HP is another story, I also port my own heads which takes a lot of time and skill and blueprinting and balancing is necessary. Try one, the worst thing is it either wont run well or it will blow up. Either way at least you tried.
    Aug 2008
    Huron Ohio
    2000 WS6 Trans AM
    I'm looking for a mild engine I wanna top 425 NA I'm doing iron cause I may want to sc or nitros it and I would just feel more comfortable with an iron block
    Will I'm in Ford Hell. If it isn't a Ford motor, then it's a SBC 350. It's like LS motors are future technology here.
    We have a LS following building here, it's just you can't throw a piston without hitting a Ford Mustang here.
    Aug 2008
    Huron Ohio
    2000 WS6 Trans AM
    I thumbed through the book and it looks like it'll help a lot. Even if I do an lq4/9 the assembly is still very similar
    Its the same if you have a 2000< the pre 99's (and some 99's) have a slighty longer crank. But from 00' on for sure same crank. Ideally look for a 00-04 LQ4/9. They have the 24 reluctor wheel already installed.
    Veteran 35th-ANV-SS's Avatar
    Wherever life takes me
    02 35th LE Camaro SS
    Quote Originally Posted by 2002ssslp View Post
    Pretty expensive error just to say you tried it lol.
    Aug 2008
    Huron Ohio
    2000 WS6 Trans AM
    Ya the GEN 3 lq4/9 are the better ones to get I think it'll be an ok build everything is pretty detailed in the book so we shall see.
    Junior Member speedfreak1's Avatar
    Mar 2011
    Parma,Ohio
    summit racing has lq9 blocks for around 750 with most machine work done.
  1. Question: Building a 600+ hp motor???
    By Tylumpy in forum Internal Engine
    Last Post: 06-17-2011, 02:21 PM
  2. building a motor
    By pontiac 219 in forum Internal Engine
    Last Post: 04-20-2010, 07:19 PM
  3. hey guys building motor what cam to get
    By fast93ta in forum Internal Engine
    Last Post: 07-17-2008, 07:30 PM
  4. Building up the motor
    By 98camaro in forum Internal Engine
    Last Post: 04-16-2008, 06:49 PM
  5. Building a motor for a turbo
    By 1986camarojoe in forum Forced Induction
    Last Post: 09-30-2006, 04:36 AM
