Results 1 to 20 of 21
Thread: Automatic Rear View Mirror???
04-17-2006, 01:37 AM #1
Did GM offer a rear view mirror on the F-Body that would dim automatically?
Has anyone tried adding one and will the power supply for the interior lights on the stock mirror plug right in to a GM mirror with the electric eye type auto-dimming mirror?
It's the only "luxury" item I would like that I don't have.Black 2002 SS
SLP Airbox Lid, K&N Filter, Flowmaster Exhaust
CDT Speakers + Sub
04-17-2006, 04:33 AM #2
Would love to see such an item.
Rob
04-17-2006, 08:03 AM #3
You can get an auto-dimming mirror with compass and outside temp for about $300. They're made by Gentex (OEM supplier for GM) and marketed by Mito Corp at http://www.mitocorp.com/html/nightvi...ingmirrors.htm. They also have models with only auto-dimming (no compass, etc.) but those don't have the map/courtesy lights.
They take a little more installation than just plugging into the existing wiring (you have to run the temp sensor outside) but it's not difficult.
04-17-2006, 08:54 AM #4
Thanks, I may grab one of those!
- Finding them (same brand) on eBay and other sites for over $100 less than the site you posted, hope you didn't buy there!Last edited by BigFrog; 04-17-2006 at 09:04 AM.
04-17-2006, 10:12 AM #5
Originally Posted by BigFrog
Yes, actually I did. There weren't any on ebay at the time (4 years ago). Maybe it's just as well though because I had a warranty issue that they took care of very quickly. Just be sure you get the model with the map lights - most of the mirrors they make don't have them.
04-17-2006, 11:44 AM #6
I found http://www.sportsimportsltd.com/nigvisrearvi.html for about $199 ... I was thinking about getting one as well ... decided to get a stereo installed with speakers instead ... may get on here soon .. anyone have any pics of one installed in a TA?
05-11-2006, 09:14 AM #7The Palmetto State
- Summerville, SC.
Triple Black- 2000 Camaro SS 'vert
I installed one from a late model Tahoe in my convertible about a month ago. I bought it on Ebay with the temp sensor included for 85 bucks.
05-11-2006, 03:19 PM #8Heavy Set Thin Guy
- MA
Quicksilver Metallic- 2005 Pontiac GTO
How hard would it be to install one in a hardtop or t-top car? I like the idea of the temp and compass in there. I have one in my Caddy.
05-11-2006, 04:42 PM #9The Palmetto State
- Summerville, SC.
It's not hard at all. If I can do it, and believe me I'm electrically illiterate, then it would be no problem for someone with basic skills to hook one of these up in any car. The one I bought from Ebay is a Gentex mirror with a seven pin plug in the back-
Originally Posted by t/as&dds
GM wire harness color function
PIN 1 PINK POWER +12 volts
PIN 2 BK CHASSIS, GND
PIN 3 LT GRN BACKUP LIGHTS
PIN 4 GY TO AUTO DIM OUTSIDE MIRROR
PIN 5 PINK TO AUTO DIM OUTSIDE MIRROR
PIN 6 DR GRN/WT TEMP PROBE
PIN 7 BK/WT TEMP PROBE
Note: Pin 3 is to be connected to the backup lights to turn off the auto dim feature in reverse. If you intend not to use this feature connect the LT GRN wire to chassis ground. If this pin is floating the auto dim will not work properly. Hope this helps. (SOURCE) http://www.the12volt.com/installbay/...?TID=8560&PN=1Last edited by Roadhouse; 05-11-2006 at 05:47 PM.
07-23-2006, 07:49 AM #10Heavy Set Thin Guy
- MA
Where did you mount your temp sensor? I'm thinking that somewhere under the hood wouldn't work too well since it could read hotter than it really is. Thoughts?
07-23-2006, 05:27 PM #11The Palmetto State
- Summerville, SC.
Sorry for the late reply, I was out of town.
I have it mounted on the passenger side fiberglass radiator support behind the headlight. I did have a pic on imageshack but all it shows me now is a red X.
07-24-2006, 11:51 AM #12The Palmetto State
- Summerville, SC.
Here is new pics of temp sensor location on my Camaro.
07-31-2006, 05:25 PM #13Member
- Oct 2005
- Austin, Tx
Black/Black- 2000 Trans Am WS6 A4
I wouldn't put it in the engine bay... the measurements would be skewed by how friggin hot it gets in there....
07-31-2006, 05:32 PM #14The Palmetto State
- Summerville, SC.
You are correct. like after the car sits a while in the sun. After I start it back up a drive away it registers correctly.
Originally Posted by ScrapMaker
08-17-2006, 10:00 AM #15Junior Member
- May 2006
- Bay Area, California
Silver- 2002 Pontiac Trans Am WS6
Did that bracket come with the temp sensor or did you have to buy it?
I just ordered the mirror for my trans am and they are changing the display to be in red to match my interior (which will look a lot better then the blue display).
08-17-2006, 01:52 PM #16The Palmetto State
- Summerville, SC.
Yes sir, the bracket was included.
08-18-2006, 12:04 PM #17
08-18-2006, 01:46 PM #18Junior Member
- May 2006
I contacted Gentex and Mito Corp. (Gentex's supplier) and I was referred to Bob Prim @ R T & Associates ([email protected]) and he will change the screen for you for a whopping $20 more than the mirror costs ($210 including shipping via UPS). I paid him through Paypal and he told me that I should have the modified mirror in less than a week. The great thing is that it will still have the factory warranty b/c they modified it and not by yourself. The only other mirror that had the capability (or so I was told) of having the red display from the factory is the one with homelink (GENK60), which would've been cool, but the cheapest I could find it was for $400!!! For a mirror, I'm good with the one I got.
08-18-2006, 02:33 PM #19
my kind of guy haha ebay is the key ... either that or your local junkyard...where you could pick it up even cheaper.. just know what vehicles they come in .. ...
its a nice lil addition but as for the dimming part I dont need it my back window is dark enough especially at night because of the tint..
08-18-2006, 02:40 PM #20
hell just look ebay you can findem cheap ... theres a shitload of them on there right now ... just make sure the auction includes the temp sensor .. wire harness.. and is auto dimming..
http://search.ebay.com/search/search...ass&category0=Last edited by illcul8troffcr; 08-18-2006 at 03:03 PM.
2002 Camaro SS #1539
MTI Clear AirLid /Magnaflow catback/Polished Hotchkis Strut Tower Brace/K&N Filter/Bilstein Suspension/
http://www.cardomain.com/ride/553601
http://www.fquick.com/illcul8troffcr
Auto Dimming Rear View Mirror Camaro SS
By chaosinfinite in forum Camaro / SSReplies: 3Last Post: 10-09-2011, 08:48 PM -
Question: rear view mirror lights
By fbodyNATION in forum Stereo and ElectronicsReplies: 14Last Post: 08-03-2011, 10:19 PM -
Rear view mirror/with compas
By 98maro in forum General HelpReplies: 6Last Post: 01-12-2011, 10:36 AM -
Rear View Mirror Problem
By Rhinohuey in forum General HelpReplies: 5Last Post: 04-06-2007, 09:56 PM -
Rear view mirror courtesy lights
By Fastcar in forum General HelpReplies: 2Last Post: 01-20-2006, 09:59 PM
