Results 1 to 10 of 10
07-06-2013, 05:41 PM #1
HELP! Missing head on couple bolts on stock exhaust manifold
Greetings and happy 4th of July weekend!
I've been doing some work on my 2000 Formula, and finally think I have it down to the last issue to get inspection - driver side cat.
I broke all 3 studs holding the cat to the manifold, and I was expecting this, car has 277,xxx miles. I bought a set of exhaust manifold
gaskets when I bought the new cat. So I went to take off the manifold (header) and found bolts on either side of cyl 1 and 3, but only
1 bolt on the forward side of cyl 5. When I took off the bolts that were there, I found what looks like the remainder of 2 bolts with no
heads between 5 and 7 and outside of 7. This don't sound right to me. Only possible time that the header would have been off is when
the dealer replaced the cat under warranty, and car was under 100,xxx. I just need someone to confirm I haven't inhaled too much PB
fumes . . . Thanks!
Gotta get this running by Monday so I can tee ta to work!
2000 Formula - 6spd & t-tops
300,000 + smiles
07-06-2013, 05:55 PM #2
Ouch. There are supposed to be six (6) bolts securing the manifold to the head. Looks like that head will be coming off to remove the broken off bolts.
07-06-2013, 06:08 PM #3
Thanks Jeff.
Still have about 1/4 inch or so sticking out, will have to try some vice grips on em.
I updated my sig pic
07-06-2013, 06:58 PM #4Junior Member
- Jul 2013
- Jacksonville FL
Pewter Gold- 2000 Camaro Z28
Ouch, is there some of the bolts sticking out to get the bolts off?
07-07-2013, 01:06 AM #5
I assume they broke when someone tried to take them off so doubtful you'll get lucky with visegrips. Do you have a torch to head them up? Sometimes if you heat them cherry red, and let them cool down, the expansion and contraction breaks the bind between the steel and aluminum.
07-07-2013, 04:13 AM #6
You have a chance then at removing them. Unfortunately, the fact that they are already broken off probably means that the threads have bound up. Steel and aluminum do not play well together and can cause some real headaches. I would hesitate to go at them with a large torch... but something like a Henrob that has an ultrafine flame could conceivably be enough to break them free. I have had luck with simply a propane torch and an old candlestick. It's not really hot enough to damage the heads, so you can heat the surrounding area and then touch the candle to the broken bolt. The wax will melt and wick into the threads providing lubrication. Go easy and excersise lots of patience. Good luck!
07-07-2013, 05:53 PM #7
I got them out! YAY!
Vice grips (pun intended, if you need them somethings BAD) pb blaster and lots of patients.
Trick was to get the vice grips cranked down hard enough that they didn't just slip. Then tap tap tap till it moved just a little, then repeat . . . .
for something like 2 hours!
Thanks for the advice all!
07-07-2013, 06:14 PM #8
Congrats! You saved yourself quite a bit more work. If you can, clean the holes out good with a threadchaser and be sure to utilize anti-sieze on the new bolts just in case you have to go there again in the future.
07-07-2013, 06:38 PM #9
07-08-2013, 02:39 AM #10
^^ Exactly. I went with stainless Stage 8 locking fasteners on our car when the headers were installed. You also can't beat the stock GM exhaust manifold gasket.
Help: Missing 13mm bolts in shifter!
By kmassner in forum Manual TransmissionReplies: 0Last Post: 06-15-2011, 12:06 PM -
stock head bolts
By shadowsnkx in forum Internal EngineReplies: 2Last Post: 08-31-2008, 10:39 AM -
exhaust manifold bolts.
By luvmyz28 in forum External EngineReplies: 16Last Post: 08-12-2008, 08:02 PM -
fs stock exhaust manifold, y pipe and cats
By Z28_SS in forum Parts For Sale / TradeReplies: 3Last Post: 06-29-2007, 02:30 AM -
Exhaust manifold Bolts Wanted
By xpauliber in forum Parts Wanted / TradeReplies: 1Last Post: 07-20-2006, 12:00 PM
