07-04-2013, 09:05 AM #1
- Jul 2009
- North of the Motorcity
What lubrication would you use for a throttle body?
Not on my LS1, but it should apply to any TB.
My TB on my 98 Jeep GC is sticking alittle, I'm going to clean it and was wondering what I should use to lubricate the moving parts.
Any suggestions?
07-04-2013, 11:23 AM #2
- Jun 2011
- Branchville, NJ
I use white lithium grease. Just make sure you clean the TB correctly and do a good job at the blade mount.
07-04-2013, 11:42 AM #3
- Jul 2009
Cleaning will be thorough, I'm going to take it off.
07-04-2013, 07:05 PM #4
I never put any lubricant on my TB's. I do remove it and clean it real good. The main thing is to make sure the blade moves easy and that it has tension from the spring. I don't think some lubricant will hurt but don't put a lot of it.
07-05-2013, 09:03 AM #5
- Jul 2009
Will do, thanks guys!
07-05-2013, 04:05 PM #6
- Jan 2009
- North Jersey
I could be wrong, but I believe throttle body cleaner has lubricant in it. Spray the TB, wipe it down real good and you should be good to go.
07-05-2013, 05:12 PM #7
- Aug 2007
- Corn and Soybean fields
The sticking you're feeling is the build up in the tb. Give it a good scrub and sticking will be gone. No lubrication needed
07-07-2013, 03:07 AM #8
- Jul 2009
I sadly still haven't done this.
I was going to soak it in parts cleaner, but TB cleaner will suffice?
07-07-2013, 12:40 PM #9
- Jan 2009
- North Jersey
No need for parts cleaner.
4.8 Timing chain lubrication
By GMJim in forum Internal EngineReplies: 5Last Post: 12-27-2015, 10:22 AM -
throttle body
By fastlt196 in forum LT1Replies: 0Last Post: 03-24-2009, 03:20 PM -
Which Throttle Body??? S3 vs. BBK
By 99blueZ in forum External EngineReplies: 19Last Post: 10-11-2006, 04:19 PM -
Lubrication Points
By Shatterz in forum General HelpReplies: 2Last Post: 04-20-2006, 08:40 PM -
98-02 stock LS1 f-body throttle body
By noblesramair in forum Parts Wanted / TradeReplies: 2Last Post: 03-04-2006, 05:59 PM
