06-30-2013, 06:45 AM #1
p1336 code - crank relearn condition
Have had a code on the z28 all summer and it wont go away. It says...
Crank sensor system variation not learned. Engine running then ecm did not detect any crank sensor variation values. Perform a crankshaft sensor variation relearn, system will relearn from normal driving.
So...i mean its been on for months now and it hasnt gone off so i assume that the ecm hasnt relearned. It doesnt seem to have affected the driveability of the car so far. It came on once about this time last year and went off and then it was on when i took it out of storage this spring and has been on ever since.
Anyone run into this before and how did you solve it? Any insights?1999 Z/28
M6 w/ Hurst shifter and SLP skip shift eliminator, drilled rotors, Y3F package, SLP lid w/ K&N filter, VFN fiberglass 2" cowl hood, TSP 1 3/4" headers & ORY
06-30-2013, 08:38 AM #2Former Mopar Man
- Jun 2011
- Branchville, NJ
Did you change the program or put a tune on the car before the code came into play ?
06-30-2013, 10:15 AM #3
Yess...last summer i had the car tuned for my long tubes. But there was no light on for a couple of months after it got tuned. Then it came on and went off once for about a day and then it was off for the rest of last summer. Put it in storage and took the battery out...put it back in this spring and fired it up and bingot...ses light .
07-01-2013, 04:48 AM #4
You need to do the relearn procedure using a TECH II device, or I am told EFI Live.
Until this is done, you are running in "limp mode" which you should see a decrease both in performance and gas milage.
The cam sensor or the reluctor ring could have gone south, or just out of sink with the crank sensor.
SteveC
07-01-2013, 07:58 AM #5
thanks. i'll get a hold of my guy and see when he can plug it in.
07-02-2013, 05:41 PM #6
gotta love knowin guys who have the right tools. stopped by his place tonite and he hooked up...about 2 minutes later he was done and the light was off. so far so good...and the car runs soooo much better now. i used to be able to sit at a stoplight and i could feel it misfiring slightly although it never came up with a misfire code.
now...just have to get the bumper repainted and figure out why my cruise control doesn't work...
major issue not starting - crank relearn ? expert needed
By devic in forum External EngineReplies: 14Last Post: 07-31-2012, 03:17 AM -
P1336 code ??
By onebadazzsrt in forum Computer & TuningReplies: 2Last Post: 09-04-2008, 03:27 PM -
ls1 gto threw a code. crank sensor: help
By Raoul-Duke in forum GTOReplies: 7Last Post: 01-08-2008, 12:22 PM -
Do I need a crank sensor relearn?
By TransAmcoupe98 in forum Computer & TuningReplies: 7Last Post: 10-13-2007, 10:12 AM -
FS: LS6 Intake & LS1/LS6 Crank Like New Condition - SOCAL local pickup only!
By Sandragnx in forum Parts For Sale / TradeReplies: 6Last Post: 08-23-2005, 03:20 PM
