Results 1 to 3 of 3
Thread: Convo Pro-MT Combination??
04-16-2006, 01:27 PM #1Junior Member
- Dec 2005
- Canton, OH
Gold- 98 Z28 LS6
I have a 98' Z-28...Would I be safe to use 15x10 or 15x8.5 Centerline Convo Pros along with MT 26x10x15??? I don't want to grind calipers or get out the BFH (haha) so would this be a safe choice?
04-23-2006, 05:08 PM #2
10" will stock out over 2" from the fenderwell. just tried it with a friend of mine's convo pros. they only come in two offsets. 3 3/8" and 5". they cleared the calipers just fine. run the 15 x 8.5 with 5" backspacing and you'll be fine.
http://centerlinewheels.com/wheels_f...15%20x%208-1/2
00 5855 507 15 x 8-1/2 5" 5 x 4-1/2, 4-3/4" dual bolt pattern
00 5855 547 15 x 8-1/2 5" 5 x 4-3/4" single bolt patternCold Air Intake, Muffler Delete, Vinci High Performance Dual Valve Springs, Hardened Pushrods, Yella Terra 1.85 Rockers, Some Hydropdipped Stuff, Strut Tower Brace, Some SS Badges, boost/vacuum gauge, fuel pressure gauge, some checkered stripes, drilled/slotted rotors, ZL1addons Stealth wickerbill, Ruxifey LED side markers
05-02-2006, 10:48 PM #3Junior Member
- Apr 2006
- Memphis
White- 96 Camaro
Here is an idea for ya. I minny tubed my camaro in 1 inch on each side that may help if you want to run a 8.5 inch rim with wide tires.
Big G
Convo Pros In here
By 1slowbusa in forum Wheels and TiresReplies: 1Last Post: 06-03-2011, 06:50 AM -
Which 4th Gen combination did you like the best?
By JwMonE99 in forum Camaro / SSReplies: 22Last Post: 05-19-2008, 02:06 PM -
convo pro's wanted !
By dentmasters01 in forum Parts Wanted / TradeReplies: 0Last Post: 11-06-2007, 08:27 PM -
2 15x8.5 Centerline Convo Pros
By mjdwyer23 in forum Parts For Sale / TradeReplies: 3Last Post: 02-12-2007, 06:57 AM -
FS: Full set of Center Line Convo Pro rims
By arieso94z28 in forum General ClassifiedsReplies: 2Last Post: 10-23-2005, 05:43 PM
