Results 1 to 20 of 22
06-14-2013, 09:48 PM #1
Anyone have advice for a mystery A/C leak?
Starting in 2011, my A/C system stopped blowing cold. In prepartion for a trip to AZ (from WA), I took it to the dealer to have it fixed. They said given my car's age (1998), it was probably going to have stay at the the shop a couple days, because it's never "just a leak" at that point. Anyway, they tested it, used the dye, let it run for 2 hours, etc, etc and the system held pressure.
A few months later (when I decided it was time to use the A/C again), I was lothe to discover it was not blowing cold. Took it to a new friend who works at the dealer here, he tested it, it held pressure, so he recharged it. Days later it was not cold anymore.
Some time later, I took it to school and worked on it with my teacher. We drained it, filled it with nitrogen; it held pressure. We filled it with dye. No leak. We used soapy water... no bubbles. We even used the little sniffer thingie. No leak. We replaced the low side Schroeder valve and over charged it to 2.1 lbs. Tested it. It blew 41 degrees with an ambient temp of 71.
Held pressure for a few months... and then blew ambient air. Took it back to my friend at the dealer, and we went through it together in his stall. We could not find any leaks. We replaced the high side valve. Held pressure (as usual). After about a week, maybe a week and a half, it's blowing hot (ambient Phoenix summer air) again.
I'm wondering what to do next... Anyone have some experience with anything like this?
Help greatly appreciated.
06-16-2013, 07:12 AM #2
so everytime it blew ambient air it was checked with the pressure gauges and it showed that it was low on gas? Was the compressor running not running?
06-16-2013, 05:50 PM #3
- Jun 2011
- Branchville, NJ
It's likely a leak from under the dash. Not a fun or cheap job.
06-17-2013, 12:37 AM #4
Compressor still works.
Interesting about it being a leak from under the dash. Even still, the leak would have to be amazingly slow to not register on the gagues, no? The system as a whole is supposed to be sealed.
06-17-2013, 05:24 AM #5
06-18-2013, 01:29 PM #6
yup it could be a pin hole like the other members suggested. you will not see a drop in pressure with a small hole like that. If is not an easy job to replace the evaporator inside the dash. are you checking around the orings?
06-18-2013, 06:44 PM #7
- Jan 2009
- North Jersey
^^this. We had a Kenworth dump truck come to our shop for a recharge a few weeks ago. Came back yesterday for another recharge. My coworker had to change the O-rings.
06-18-2013, 07:53 PM #8
O-rings, huh. Any idea how many O-rings are in our system? I have a 98.
For those who do this for a living: if it were your shop, how would yo determine if the job was a success? Just give it back to me and "wait and see"?Last edited by Naaman; 06-18-2013 at 08:01 PM.
06-19-2013, 03:08 AM #9
I did my compressor and replaced them all. I have an extra o ring kit. let me find it and I will post. I believe is around 7 o rings.
06-19-2013, 11:10 AM #10
have you tried the dye & florescent light yet?
06-19-2013, 12:26 PM #11
06-19-2013, 05:15 PM #12
Did you vacuum down the system each time before you recharged it?
Replace the o rings, lube the rubber ones with pag oil before installing. Rather than charging it, pull a vacuum on the system (as if you were recharging it) and drive it a while to see if it holds the vacuum. If a system can't hold vacuum for a hour, it has problems.
Jon
06-19-2013, 11:12 PM #13
06-20-2013, 09:38 AM #14
Did you check inside the car?
06-20-2013, 10:02 AM #15
- Dec 2005
- Laurel, Maryland
Time for an AC Delete
RACECAR!!!!
06-20-2013, 11:49 AM #16
Not in AZ......too damn hot in summer
06-20-2013, 06:03 PM #17
You know I HAVE been tempted to just rip the system out of there... But then my wife won't ride in the car with me... :P
06-20-2013, 08:22 PM #18
06-21-2013, 02:34 PM #19
- Apr 2010
- Alabama
1998 Trans Am WS6 - Phantom
421 LQ9 14.8:1 on E85 Build/
06-21-2013, 08:13 PM #20
LOL! Yeah, she'd ride Oct-May, anyway... It's turning out that my engine noise may be something way more serious than I thought, so I'll likely be putting this on hold for a while. We'll see...
mystery leak
By johnfin in forum Firebird / WS6Replies: 3Last Post: 12-04-2012, 03:56 PM -
Mystery coolant leak.
By TWO-TONS-OF-FUN in forum General HelpReplies: 17Last Post: 01-01-2008, 01:18 PM -
Mystery Coolant Leak
By 7camaro7 in forum General HelpReplies: 20Last Post: 12-15-2007, 06:18 PM -
ttop leak, hatch leak, and window motor problems
By ATCharming in forum General HelpReplies: 41Last Post: 07-23-2007, 02:30 AM -
advice on coolant leak
By SeVeReDiStOrTiOn in forum General HelpReplies: 35Last Post: 12-19-2005, 06:38 AM
