Results 1 to 19 of 19
    Member adham's Avatar
    Newport News, VA
    2000 Pontiac Trans Am
    new brake rotors
    i need help with new FRONT brake rotors and pads
    i know the pads should be ceramic but which rotors do i go with?
    i have been looking on ebay and they have front rotors in the $110 range
    yeah u might say they r cheap, but they are MUCH better than what i have now
    any suggestions r appreciated
    thanks
    Newport News, VA
    anybody?
    Newport News, VA
    Senior Member
    Jacksonville, FL
    A lot of people go with the Auto Zone rotors.
    Senior Member
    Jacksonville, FL
    I just plugged in "which autozone rotors" into search and got a bunch of threads w/rotor recommendations.
    Newport News, VA
    u mean the $40 ones?
    duralast?
    What's your budget on them though? Can you go with slotted or are you trying to stay inexpensive. Warping the rotors on these cars is a given. Torque them to spec and that should help a little. I think most people crank the lugs to tight and that leads to warpage but most rotors are going to warp. I would guess if you move up to slotted or slotted and drilled it would help but I haven't done that yet. I just learned to live with it. Mine really aren't that bad but I make sure to not overtighten the lugs and don't have many high speed stops on them ( a few though ). Good luck and just do some searches. You'll figure out which ones people have the best luck with.
    earf
    I have powerstop rotors - ill never go back.
    Newport News, VA
    from where and how much?
    Commerce Ga
    Black, Blue
    07 TBSS, 07 GSXR1000
    SUmmit sells Power Stop or check with wholesale direct parts.
    Newport News, VA
    is there anything that is good but cheaper than that?
    i dont want to pay $120 for each rotor
    i dont care for all the high performance stuff, anything like the stock ones will be fine with me
    I went to Playboy Mansion FantaZGuy28's Avatar
    Bakersfield/Long Beach Ca
    YJ
    04 GTO M6
    WS6Store.com has drilled/slotted rotoworks rotors for 169 for all 4 rotors.
    Bay Area
    00 ss camaro
    I went with the autozone duralast rotors. I also went with hps hawk pads. You can find the pads on ebay for like $75. I did alot of research befor i bought the rotors and pads. Every one told me this was perfect and its not that much money.
    Newport News, VA
    thats more like it
    thanks for the help guys
    Impounded YoMommasTA's Avatar
    ne pa
    i like the advance auto rotors.they give a 1 year warranty with them.
    Tx
    2001 camaro
    found my on ebay for 104.00 all around....slotted
    Quote Originally Posted by adham
    thanks
    i have them on my 2001 camaro if you want pics i can send you some
    Newport News, VA
    Quote Originally Posted by 2001ls1
    sure, that would be nice
    Poway, Ca
    SOM
    2001 Z28 (Sara)
    I went with the Baer Eradispeed rotors, with Hawk HPS pads, however if a budget is in mind, this is not the way to go.
    SteveC
    Morris County NJ
    2002 Camaro SS
    I put on a set of Brembo "OEM blank" replacement rotors. Got them from TireRack, I think they were $65 each. They've been on the car for 20,000 miles now and have been wonderful.
    They do nothing for appearance, they look stock. But they are functional and reliable. I'm running OEM GM pads with them.
  1. Corvette Brake Rotors - Give Me A Brake
    By Ed Blown Vert in forum Corvette
    Last Post: 09-17-2010, 03:39 PM
  2. ? on brake rotors
    By qwik219d9 in forum General Help
    Last Post: 06-02-2009, 02:57 PM
  3. Brake Rotors????
    By bobbert350 in forum Suspension and Handling
    Last Post: 05-02-2007, 04:44 AM
  4. Brake rotors
    By CandyRedZ28 in forum Appearance Section
    Last Post: 09-07-2006, 03:22 PM
  5. Brake Rotors
    By jbmcmillan in forum General Help
    Last Post: 08-07-2006, 10:33 AM
