05-30-2013, 01:09 PM #1Junior Member
- Apr 2012
- West Chester, PA
Black/White | Black- 98 TA | 01 WS6
Check Gauges Light & Bouncing Needles at High RPMS (Video)
Hey all,
My buddy Steve and I rebuilt the top end of my motor a couple weeks ago. No real issues at all, and this really isn't an "issue" either. When I get to higher RPM's through the gears I'm seeing the needles bounce and the Check Gauges light on. It's slightly annoying as don't want to get past redline. With bouncing needles it's hard to tell exactly what RPM I'm really at.
Here is the video:
I'll grab a better quality video shortly... Any idea's as to cause? I'm thinking BCM, gauge cluster itself, bad ground?
Thanks...
05-30-2013, 01:45 PM #2Senior Member
- Oct 2008
- Coral Springs, Fl
I would look over all your grounds first like you mentioned, is this a problem that started after the rebuild?
06-04-2013, 05:52 AM #3
I agree with tater. Go back and look at all the wires that got removed and check the grounds as well.
06-05-2013, 08:45 AM #4Junior Member
- Apr 2012
- West Chester, PA
Everything looks good, including the grounds on the back of the driver side head.
06-05-2013, 03:52 PM #5Senior Member
- Oct 2008
- Coral Springs, Fl
Might be a good idea to double check the connections on the PCM. Maybe one of the pins has a bad connection
06-05-2013, 04:52 PM #6
I'll third it, really sounds like a ground or connection issues. Any wiring get damaged during the rebuild, or routed to close to the exhaust when things went back together?
check gauges light
By ls1wallen in forum General HelpReplies: 5Last Post: 02-25-2011, 05:30 PM -
Help: check gauges light
By GWTWayne in forum General HelpReplies: 6Last Post: 08-11-2009, 05:57 PM -
Check Gauges Light
By wnmech in forum Firebird / WS6Replies: 5Last Post: 04-02-2007, 10:58 AM -
Check Gauges Light?
By SailorZ28 in forum General HelpReplies: 5Last Post: 04-03-2006, 02:33 PM -
check gauges light
By wooten in forum Computer & TuningReplies: 6Last Post: 02-14-2006, 02:22 PM
