Results 1 to 2 of 2
05-21-2013, 04:46 PM #1Junior Member
- May 2013
- United States
Red- 1999 Trans Am
1999 Trans Am Fuel System Diagram, Info
Hi everybody, I just finished resurecting / rescuing a 1999 Trans Am with about 160,000 miles that a friend had sitting for over 3 years. Before anything was done and the key turned, I took the tank out, cleaned it up, got all the disintegrated metal pieces of the fuel pump out and got a new aftermarket pump, replaced the injectors and blew the fuel lines off. Fluid change and the car started up.
My problem and suspicion is that somebody may have messed with the fuel system because I had the plastic flex tube inside the pump that goes from the pickup to the feed line come off 3-4 times, then I broke one of the 3 plastic tubes on top of the pump trying to take the line off, so I got a new pump. By this point I had created the magic port in the trunk for easy access to the pump. Now I got a new pump and after a 50 miles I go to start the car run for a few seconds and then died. This time the plastic flex tube exploded.
I am suspecting that something is missing or is not right with the fuel system and created too much pressure in the tank or the pump itself. I was wondering is there is a diagram that shows the fuel system front to back so I can compare it and see it the problem is quickly identifiable. Or if anyone had that problem before please let me know how it was resolved. Any and all help will be greatly appreciated!!
05-21-2013, 06:41 PM #2Former Mopar Man
- Jun 2011
- Branchville, NJ
Pick up a GM repair manual off Ebay, you are going to need it during the resto.
1999 Trans Am traction control system and ABS brakes
By bigabb in forum Firebird / WS6Replies: 4Last Post: 03-15-2011, 02:49 PM -
Supermaxx system info
By kiddynamite in forum Firebird / WS6Replies: 2Last Post: 07-06-2010, 05:57 PM -
2001 WS6 Trans Am front body diagram
By 2001ws6ta in forum Firebird / WS6Replies: 2Last Post: 05-06-2009, 06:41 AM -
Warning System Info
By Ed Blown Vert in forum Board AnnouncementsReplies: 17Last Post: 07-26-2007, 11:24 PM -
looking for a monsoon wiring diagram for a convertible 2002 trans am
By mr.yellow in forum Stereo and ElectronicsReplies: 2Last Post: 11-14-2006, 01:27 PM
