Results 1 to 19 of 19
    Junior Member JadedBird's Avatar
    Jun 2012
    Kentucky
    WS6
    new tranny mount
    so i was going to buy a tranny mount
    ws6 store has 2 options... energy suspension and prothane..
    which should i choose?
    i have poly motor mounts so should i go poly on the tranny mount as well?
    both are poly, energy suspension has a good rep. I've gotten a set of their engine mounts and after pulling the tranny & engine last night I know I need to add a tranny mount to my parts list.
    LS1 or bust b.lee's Avatar
    Aug 2006
    SE, Michigan
    Blue
    00 Z28 6Spd / 03 Z71 LT
    The car is going to viberate more so just be ready for that
    At idle, driving down the road, freeway, etc
    If you dont want any extra vibration, use a stock mount
    Coral Springs, Fl
    Sunset Orange Metalic
    My Prothane vibrates a lot less than my buddy's Energy Suspensions one. He ended up going back to stock he hated it so much. It's all a matter of opinion but i like my Prothane one.
    The poly mount in our car lasted a couple of days before I yanked it and threw the stocker back in. Way too much vibration imo.
    phoenix
    04 2500 4x4 crew cab
    It will chatter/vibrate at certain RPM's. I like mine, but I also like the noise and vibration. Lets you know you got something alive under the car.
    Jun 2012
    Kentucky
    WS6
    well. my tranny sure moves around alot and i could litterally sword fight with my shifter
    my poly engine mounts are doing fine and i dont mind them. but maybe ill try the poly. if worse comes to worse, ill just jack it up yank it out and throw a stock one back in there
    Quote Originally Posted by b.lee View Post
    I think after I finish throwing in this 6L with a Polluter Stage 3 cam Iim building the vibrations aren't going to matter anymore
    was this before or after the SFC's Do you have the TA still on the tail cone?
    Jun 2012
    Kentucky
    WS6
    Yeah i have sfc installed already and im currently building an ls2 with a l92top end cammed to make 450+
    After 2 point SFC's and installation of a tunnel mount torque arm. It seriously sucked.
    Aug 2012
    Virginia
    Midnight Blue
    2002 Camaro Z28
    Please allow me to take this thread off on a tangent. I am going to install long tube headers soon and have read this is the time to do motor mounts. Everything I have read says go with poly motor mounts. I assumed the trans mount would be changed to poly at the same time. So, you guys are using poly motor mounts and rubber trans mount?
    Laurel, Maryland
    2000 Grand Prix GTP
    2000 Trans Am WS6 M6
    Vibrations = fun
    They don't bother me at all.
    Poly engine mounts and a stock rubber trans mount here. No issues at all.
    Aug 2012
    Virginia
    Midnight Blue
    2002 Camaro Z28
    So the difference in mount material will not cause cracking of the trans case? I recall reading somewhere that could be an issue because the front of the motor/trans assembly is not allowed to vibrate as much as the back half causing issues. It has been a long time since I looked into the benefits of different mount types, so please bear with me.
    << If launching our car at the track like this hasn't broken the transmission case, I am guessing that is nothing more than an unfounded rumour. If anything, the poly mounts better dampen and absorb the side-to-side movement which would be the torsional stress on the engine and transmission. The trans mount is simply here to hold up the back of the engine and transmission assembly.
    Aug 2012
    Virginia
    Midnight Blue
    2002 Camaro Z28
    I installed the Poly motor and trans mounts. Can't keep change in the ashtray any more, that jingles and rattles like crazy. I have noticed a shaking/ excessive vibration at 45 mph in 4th gear, shift to 5th and it goes away. I think it will be bearable. I just hate the conversations w/ every person that rides in the car.
    "What's wrong with your car?"
    "Nothing, it has poly mounts"
    "What are those?"
    "UGH"
    Member blackcar's Avatar
    Arkansas
    '02 Z28 parting-out
    Can everyone say which tranny mount (brand) they used, if the are a4 or m6, and the vibration?
    I used Prothane motor and trans on my m6 and didn't notice much difference in vibration. My shifter quit moving around and not much more (if any) vibration. I do have a little nosie I didn't have before, but only when my foot is not on the clutch and it is ideling. Like at a red light.
    Jun 2011
    Branchville, NJ
    Silver & Blue
    02 Camaro SS, 04 GTO
    Poly mounts are the best.
  1. Tranny mount
    By Justin23454 in forum General Help
    Last Post: 11-13-2010, 11:12 AM
  2. Tranny Mount???
    By redbird555 in forum Automatic Transmission
    Last Post: 08-29-2009, 10:49 AM
  3. 01 M6 Tranny Mount..
    By CamaroFan71 in forum Drivetrain
    Last Post: 12-20-2008, 07:13 PM
  4. Need a good T56 (LS1) Stock Tranny mount & Torque arm mount..
    By 1slosnake in forum Parts Wanted / Trade
    Last Post: 06-19-2006, 03:04 PM
  5. Need a good T56 (LS1) Stock Tranny mount & Torque arm mount..
    Last Post: 06-13-2006, 05:24 PM
