Results 1 to 13 of 13
    IL
    1997 Formula & 2003 cobra
    Foggy headlights? Don't waste your money on restoration kits
    Get a 2000 grit sand paper about 3 bucks at autozone, buy a cheap scratch remover, about 3-4 bucks at autozone.
    Wet sand the headlight real good and then apply some scratch off and you are done. Took me 10 minutes to get this headlight done on my fiancé's car. I wish I took before photos because it was way worse than the other one.
    Here are few pics:
    The one I cleaned was much worse than this.
    10 minutes later
    COTM July '09
    Annapolis, MD
    BLK/BLK w/CGM Stripes
    2010 Camaro 2SS/M6
    Yeah did that to ours. Started with 600 then 1000 and then 2000 and then the polish and some wax to seal it.
    I like work. It fascinates me. I can sit and look at it for hours.
    My Cardomain Site My Fquick site Custom Installs
    Oct 2001
    Colorado
    95 Z28
    If you go through a multi-step process I guarantee it will come out better than only two steps with only one level of sanding. How many steps are needed is usually determined by how bad things are. A bad headlamp needs sanded down further than 2000 though to take out heavy imperfections. And there's a reason why you want to use rotary sanding discs and polishing pads as opposed to just back and forth by hand.
    And if you havent already done it, those headlamps now need to be permanently resealed, as all of the factory coating that protects the lense is now gone. If not it will haze back over pretty quick. I'd recommend opticoat or something similarly hard and permanent.
    Jun 2011
    Branchville, NJ
    Silver & Blue
    02 Camaro SS, 04 GTO
    Saving money on LS1.com Oh yeah !
    Junior Member Blakbird24's Avatar
    Feb 2011
    Fleetwood, PA
    2010 Tahoe Z71
    2012 Cadillac CTS-V
    I always use clearcoat. A good automotive acrylic clearcoat will make it so you only ever have to do this process ONCE.
    Looks much better
    Jenks/Tulsa
    Light Pewter Metallic
    y2k 8-cylinder catfish
    Looks very good. My Camaro headlights aren't fogged, but do have some pitting in them that I'd like to get out. Anyone else got the pits in theirs?
    Quote Originally Posted by 5.0THIS View Post
    I personally just sand everything innancircular motion by hand then buff. Never had a bad result even with how bad they were on my cruiser when I bought it.
    Oct 2001
    Colorado
    95 Z28
    Circular (drill) or random orbital is always better when it comes to sanding or buffing any surface. Nonetheless it can be done by hand, just isnt the preferred method
    I usually machine buff either buffer or the drill buffer pads. The rain x kit is all hand stuff and looks decent but I think I've had so much better results with the meguiars products and drill pad this time around
    North Jersey
    Phantom Black Metallic
    2004 GTO M6
    I have to redo my passenger headlight. Did a resto job at work but it was raining and I think the rain/humidity may have contaminated the clearcoat and made it flake off.
    USA
    BLACK
    Z/28 LS1
    It is the preferred method if you like sanding by hand...........hahahahah
    Arizona
    I used 1500, then 2000. Then hit it with the buffer and 3M buffing compound that I use on paint. Then changed the pad and went over that with Maguiars swirl remover.
    Comes out nice but alot of work, and to do a good job I prefer the headlight off the car as the buffer is large. Never could get the same results using a little drill and pad, too hard to control and didn't spin fast enough, and you always have to worry about ripping the rubber surround off of the 4th gen headlights, sort of a pain.
    Anymore I just prefer to buy a set of new headlights. Never was a fan of this plastic headlight stuff that all the manufactures went to.
  1. Waste of money?
    By ls1ssman in forum Automatic Transmission
    Last Post: 07-26-2008, 06:42 PM
  2. Waste of gas/money
    Last Post: 04-11-2008, 07:49 AM
  3. A waste of Money
    By JoshieDoom in forum Almost Anything Goes
    Last Post: 04-06-2008, 10:30 PM
  4. Did I waste my money??
    By dparsons1968 in forum Suspension and Handling
    Last Post: 12-11-2007, 07:35 PM
  5. Replies: 18
    Last Post: 08-15-2006, 07:25 PM
