    Junior Member ntymd8r's Avatar
    Corona, CA
    2001 Chevrolet Camaro Z28
    Smoke from engine bay.....
    This morning when I came home from work, I pulled into my driveway and notice a small amount of smoke coming from the passenger side of my engine. I opened the hood and a little more came out. It was a lite color, not steam, but I can't tell if it was blue....It smelled more or less like a clutch burning smell....but I have no clutch problems. I can't determine where it was emitting from other than from the passenger side rear engine area
    I just got to work noe and I babied her all the way. I opened the hood with the engine running and I could smell the burn but couldn't see it. I reved her a few times and noticed a little smoke from the "air valve"? I forget what its called but I think it collects a small amount of oil. Its located on the top passenger side. Its a rubber tube that connect to this valve and then turns into a metal pipe which connects to a spot next to the front spark plug on the passenger side.
    Anyone know what problem I might be experiencing?????
    2001 Chevrolet Camaro Z28, M6, Eibach Pro-kit, BMR STB, BMR Adj-PHB, BMR RB's, BMR SB's, BMR Adj-TA, KYB Adj-shocks, K&N, SLP LM, SLP Y-Pipe, SLP Intake, Predator Custom Tuned...
    Treat her well and she'll put a smile on your face every time you get on her!
    Member Wyoming T/A's Avatar
    Powell,WY.
    1999 Trans AM 30th anniv.
    probably developed a small oil leak,1 drop of oil can smoke quite a bit ,have one of your buds ck it for you ,
    DFW
    '18 CTS-V
    '13 ZL1
    might want to look at your power steering pump and fluid also. there is a chance it could be the the rubber hose just past the metal could be or couold have rubbed a cut or hole in it. that happened to my old Z28 but only when you turned the wheels at really low speed like pulling into a parking spot you would see smoke. plus you would see the leak on the ground. regardless good luck and hope you find and fix it!
    2013 ZL1: °°590rwhp/576rwtq°°
    Roseville, CA
    05 Wrangler
    00 Z28 sold :-(
    Try replacing the gasket for the AIR tube you're describing...the one inbetween the exhaust manifold and AIR tube.
    Corona, CA
    Thanks for you responses....found the prob. The 'air check valve' was burning up on the inside. I unscrewed them both and found the whole fixture on the inside was rattleing and loose. I trouble shooted by switching them, drove around the block and opened the hood to find the other side was now smoking. It was also really hot around the 'air tube' on the valve I switched each time. This is the second pair of valves I've had to replace....the first time I had a code thrown, but this time no code....hhmmmm. Glad Kragen actually had them in stock! $40 fix!
    This was probably gonna catch something on fire, FWIW! Hope this helps others in the future...
    Member adham's Avatar
    Newport News, VA
    2000 Pontiac Trans Am
    that same thing happened to me last week
    my air check valve was broken and rattling and was VERY HOT
    i used the same fix!
  1. To smoke or not to smoke ???
    By Speedy_Gonzales in forum Camaro / SS
    Last Post: 10-13-2007, 09:12 AM
  2. got smoke grey smoke from exhaust. normal>? or not?
    By 00maroz28 in forum Camaro / SS
    Last Post: 05-20-2007, 04:19 PM
  3. smoke from engine compartment
    By adham in forum General Help
    Last Post: 02-01-2007, 11:04 AM
  4. smoke coming out of engine after seafoam ?
    By jinxeng in forum General Help
    Last Post: 11-22-2006, 08:42 AM
  5. Cold night, hard run, light smoke from engine
    By third_shift|studios in forum General Help
    Last Post: 11-23-2005, 09:13 AM
