    jacksonville, FL
    2000 WS6 Transam
    Talking Auburn Posi Noise
    I am sure that this has been posted before but just a note for anyone running an Auburn Posi in their 10 bolt. I have been experiencing a lot of noise (banging, popping, shuddering) from the rear of my TA when turning slowly into my drive way or backing out of a parking space. I happen only after the car had been driven for a few miles. I had my wife drive it into the driveway while I watched and listened. The rear wheel that was turning the fastest was actually shuddering or jerking. I put it up on jack stands and could not find anything loose. I changed the gear oil and added friction modifier that I got from Advance Auto Parts just in case it was clutches in the posi chattering. It did not fix the problem. I reread the users manual for the posi and it specifically said not to use any friction modifier but GM or Ford. I changed the fluid again and used the GM friction modifier and the problem was solved. I should have paid better attention to the manufacturer. This problem has bothered me for the better part of a year. Amazing that the problem was so simple. I hope this will save others from the same experience.
    Euclid,ohio
    1998 Z28
    If your 2000 firebird still has the original parts in the rearend,it has a Torsen 'posi',not an Auburn. Torsens are prone to 'noise' with age.
    The use of Torsens started in 1999.
    jacksonville, FL
    2000 WS6 Transam
    Smile Auburn Posi Noise
    Quote Originally Posted by oldmanZ28 View Post
    I rebuilt the rear end with 4.10 gears and an Auburn posi because the torsen gave up the ghost. I just wanted to pass along that GM or Ford friction modifier worked properly and the cheaper parts store brand did not.
    Thanks
    Jun 2011
    Branchville, NJ
    Silver & Blue
    02 Camaro SS, 04 GTO
    Torsens are a gear drive system and when they go they are gone. Same with the Auburn units but they have springs that set the needed traction. When they go they are gone as well. The units I like have clutches in them and are rebuildable. You can beat them all day long and when you are down to one black stripe you simply pull the unit out, throw in a clutch kit and fill it with oil.
  1. For Sale: 4th gen rear end 2.73 3 ch auburn posi
    By SexyTransAm in forum Parts For Sale / Trade
    Last Post: 09-11-2009, 02:24 PM
  2. aburn posi vs eaton posi units
    By TOOSHORT2000TA in forum Drivetrain
    Last Post: 04-05-2009, 06:01 PM
  3. Auburn vs. USC
    Last Post: 09-29-2006, 04:58 PM
  4. MTX Thunderform Box / Auburn POSI diff + 4.10 gears
    By StillSmokin in forum Parts For Sale / Trade
    Last Post: 04-10-2006, 08:47 AM
  5. NEW auburn posi
    By yak in forum Parts For Sale / Trade
    Last Post: 08-07-2005, 08:25 PM
